06-22-2021, 03:24 AM | #1 |
Wheto order 2020 x22 dongfang Rear Sprocket
Im trying to find out where is best to order a rear 17 tooth sprocket for my 2020 x22/crx dongfang. anything is helpful thank you
06-22-2021, 08:01 AM | #2 |
The front sprocket is a 17 tooth. You will want to install a 36 tooth on the rear. You can order a custom sprocket from PBI Sprockets as you will not find a 36 tooth already made. You can order from here. https://shop.pbisprockets.com/product.sc?productId=503
Here's the information you will need to enter. 428 sprocket, Center Hole Size. size: 64mm, 58mm if you remove the spacer ring - Size of bolt holes diameter. 10.5 circle diameter through center of all bolt holes: 96mm Important Note: Sprocket will need to be milled to recess and install the stock steel spacer ring. Here's a video on changing the sprocket.
06-22-2021, 08:25 PM | #3 |
Rear Sprocket
Yes thank you so much Jerry I really appreciate all the information
06-22-2021, 08:36 PM | #4 |
If I remove the spacer ring it will be 58mm so I don't have to do any milling or reinstall the stock ring?! is that correct
06-22-2021, 10:45 PM | #5 |
That is correct.
250cc, dongfang, rear sprocket, sprocket, x22 |
