Old 09-16-2020, 10:54 AM   #1
Falkon45's Avatar
KPM 200 Resource thread
PastorCZO:
Found a place for replacement parts
https://kpclubusa.com/collections/kpm-200
Okay, since the KPM 200 (LF200-3B) basically has an updated version of the NBf-2, and is a fairly new model, I decided to compile a resource list. Basically, instead of searching through my poorly named thread that most newcomers won't associate with what I'm doing, I'll make this one more appropriate.
Anyway, with everything I've found so far, Here's what's what.
Exhaust:
I have confirmed that the KPMOTO-Club exhaust works on this bike. It's kinda tight, but not hard to install. Just don't be afraid to force a few things here and there.
https://www.amazon.com/exec/obidos/A...im/refuge08-20
https://photos.app.goo.gl/inAND72b25C89mi48
https://photos.app.goo.gl/JfMxkxuEC9qkndKVA
Engine:
So, as I've stated before, the engine comes with two oil strainers. A coarse and fine strainer. But, if you don't think that's enough, I have found oil filters that may work: Fram ch6015-04
K&N KN-112 (confirmed fitment 3-12-2021)
Oil filter cross reference:
https://www.oilfilter-crossreference...rt/fram/ch6015
I haven't tested them yet, but I have 637 miles on the bike as of now. At 1200, I'll pop in the filter, and at 2400, I'll take it out and compare the first two oil change pictures. I'll also try and note any problems or power loss/gains I'm currently using Mobil 1 4T racing 10w-40. I'll use that same oil for the filter to strainer comparisons, then I'll switch to Castol 10w-50 4T
Here's some pictures of the oil change, and filters that could possibly work. In the filter pictures, the KN-131 is just there for size comparison.
https://photos.app.goo.gl/z3k1FxixEXpvHcJh8
https://photos.app.goo.gl/fC5YusCp8xQRUDyu9
K&N KN-112 filter install :
Also, the engine did come with a Magnetic Drain plug, so no need to go looking for one, unless you just want a different color, or aluminum.
Suspension:
Ok, these DO NOT come with a shock tool. You'll have to find one on your own.
Edit: I've found that the ER32 sized shock tool works. Here's the multi set I bought
https://www.amazon.com/dp/B08KD6RF8N...ing=UTF8&psc=1
The shock is pre-load adjustable and a two piece progressive spring setup. The fork is not adjustable. I really wish they'd fix the wording on that, because they make it sound like the fork is adjustable also. For us heavier guys, even with the pre-load maxed out, we'll still have too much sag. I'm trying to find measurements on the shock so I can see what can be removed from other bikes to fit, or for what size you will need for aftermarket shocks. I'll post links to any adjustment tools I find that can work.
For the swingarm spools, they take M8 or 8MM spools. These are readily available just about everywhere.
(NOTE: It seems as if the scrambler tires are no longer sold. The chinese market bikes may no longer be sold as scramblers anymore, and are more inline with what we get. tire links no longer work.)
Tire sizes are 100/80/17 front and 130/70/17 rear. These are CST tires, and I have found the scrambler replacement tires here:
/_yoycart_com/Product/625795363910
/_yoycart_com/Product/625795599556
The spoked wheels, if you want them, are here too:
https://www.yoycart.com/Product/615123023887/
I've not found the street tires the American bikes get. I'll be stepping up to 110/70/17 and 140/70/17 bridgestone S20 tires, but I was able to find the original tire size at Motosport.com and Revzilla.com.
Brakes:
FA197HH front and FA629HH rear. The front brakes are for a ninja 300, so any Ninja 300 pads should work. The rears are for a Grom, so there's a good place to look also.
Miscellaneous:
Rear racks, backrests, shifter and brake levers, and all kinds of goodies are found under this search.
https://www.yoycart.com/Search?Searc...00&catId=0&p=1
https://www.yoycart.com/Search?Searc...00&catId=0&p=1 UPDATE: Updated search results for yoyocart
If you want a more cafe racer look:
https://www.yoycart.com/Product/616455251080/
This list will be updated as more things are figured out.
Please feel free to add any information you have to it also.
Last edited by Falkon45; 01-11-2022 at 09:14 AM. Reason: 6/4/21 Updated search results
Old 09-16-2020, 11:32 AM   #2
Good info! Nice to have this all in one place.
2020 Kawasaki Vulcan S
Old 09-16-2020, 12:35 PM   #3
Sticky, maybe?
'Dorito' from the 'Dorito and the Luchababre' YouTube channel had mentioned the engine being a slightly upgraded NBF engine. It makes sense because on the EPA/DOT certification, the KPM200 is on its own certificate whereas the KP/KPR200 are on a different certificate, and if I remember correctly, there is a 1 or 2 horsepower difference noted in the details on the EPA/DOT spreadsheet. Slightly off-topic, the 'New' KPMini 150 also has an upgraded 150cc engine as noted on its EPA/DOT certification. Also off-topic but Lifan related, American Lifan's Facebook page teased, once again, the KPT200 adv-style bike, which could be an interesting alternative as a trail bike (vs. the common dual-sports and the Zongshen RX3 which seems a little large and heavy as a trail bike) if American Lifan actually brings it in. We already know the engine is EPA/DOT certified in both NBF and NBF 2 form, so, American Lifan--yes please!
Old 09-23-2020, 08:09 PM   #4
KPM200ba   KPM200ba is offline
Great job, this is just what I needed to know. Thank you.
Old 10-14-2020, 12:43 AM   #5
gr4321   gr4321 is offline
Yo Falkon45. Hello I'm new to the forum. I'm getting one of these KPM200's. From a local
dealer. When you ordered from Yoycart. Did you have to pay any import taxes. I want to
order some accessories, for this bike from them. And was shipping expensive.
Old 10-15-2020, 07:35 AM   #6
Falkon45's Avatar
Hi. I haven't ordered from yoyocart as of yet. I normally order from Aliexpress, and a few ebay sellers. I haven't had to pay any import fees when I've ordered from any of those sites.
Old 05-13-2021, 12:16 AM   #7
Coloradogoose   Coloradogoose is offline
For anyone looking at Yoycart I did attempt to order a few things. The shipping quote on the website estimates everything at 200 grams (just under half a pound). My order was estimated at $34 to ship by the website, so when the actual shipping quote based on actual weights came it at $250 I cancelled my order.
Old 04-16-2021, 03:48 PM   #8
PastorCzo   PastorCzo is offline
PastorCzo's Avatar
What size rear sprocket does this have?
Old 04-16-2021, 07:08 PM   #9
Falkon45's Avatar
It's a 49 tooth rear sprocket. I have found a 45 tooth sprocket. I haven't put it on order yet. I do have a new chain ready to go, though.
Old 07-22-2021, 10:44 PM   #10
Did you ever throw the 45T on? Where did you get it from? Curious how it did with a 4 tooth drop. I'm interested in possibly changing mine out, but not sure what other rear sprockets are compatible. Any suggestions? Thanks!
Old 08-06-2021, 08:45 AM   #11
Falkon45's Avatar
I haven't ordered it yet. I need to find it again. Been busy with my yamaha and the kiddo's bikes lately, and put a lot of KPM stuff on the back burner, unfortunately. I'll try and find it, and get that and the front sprocket on order.
Originally Posted by DoujinDango
What's the coolant type for the KPM ? My owner's manual has a coolant section, but it doesn't mention what to put in it
Mine came with a bottle of coolant. It looked to be similar to engine ice, but in a random bottle. I use engine ice in all my bikes. It works really well, and you don't have to mix it. But, it is not compatible with and not to be mixed with any glycol based coolant. So, if you do use it, make sure you flush your system well first.
It doesn't take much. I thought it would take more than it did, seeing as I had to fill two radiator, plus the engine, but it didn't even empty the whole quart bottle.
Old 08-12-2021, 10:30 AM   #12
DoujinDango   DoujinDango is offline
Doh!
You've got me scared now. My bike came with oil and gas in it. I made the assumption that coolant was in it as well and that the silver bottle was replacement oil that I just wasn't going to use because it was some dumb unlabeled stuff. Press F in the chat.. I've put 500 miles on it without it throwing a code, just put the silver bottle coolant in it now. Anything I should keep an eye out for since I probably damaged it in some way?
Old 08-16-2021, 08:12 AM   #13
Falkon45's Avatar
Lol. You're probably okay. If it's not smoking or boiling over, you didn't ruin anything. These are still air cooled derivative engines. They probably left some air cooled properties in it to protect it. Just make sure you properly burped the system to have all the air out.
Next time you change the oil, make sure it doesn't look like chocolate milk. If it does, you have a BHG (blown head gasket), and it need to come apart.
I'm looking for gasket kits that can fit, actually. I want to do some head work, and kinda looking for a cam.
Also, I'm looking for an aftermarket clutch, as I think mine is slipping. Heavy boy, plus being REALLY hard on the bike with clutchless shifts, hard full throttle acceleration almost all the time, and a few attempts at clutch dump wheelies takes it's toll. lol.
Honestly, this thing is far more durable than expected. Whoever gets it next will have a lot of upgrades. lol.
Old 08-19-2021, 11:56 PM   #14
I hear ya, most of my work lately has been to my Royal Enfield so my KPM is lonely as well. I'll be curious to hear what you find as far as front and rear sprockets and if you have any luck with a cam. I'm a tinkerer by nature so I love to mod bikes when I can. It's the only thing I don't like about the KPM. There just isn't the support other bikes have. I'd be fine to run it at stock, but half the reason I buy bikes is to play with them when I can't ride them!
Old 05-14-2021, 09:08 AM   #15
PastorCzo's Avatar
Is there a compatible shifter pedal for this bike? Mine is bent
