02-17-2020, 10:47 PM | #1 |
Stand by me
Has anyone took a grinder to their Brozz kick stand mounting bracket? The kick stand on my Brozz doesn’t come down and rest in a forward direction. The bike stands upright. I’ve found while wrenching that I’ve shifted the bikes weight at least a half a dozen to the point I though it was gonna fall. I’d have to grab the bike and reposition the stand. Yes , I know. I have a work stand but it a bear to get the bike on it as it slides easily on the painting concrete in the garage.
I was thinking if I grind away some metal it would allow for the kick stand to rest in a more forward position and be less likely to a tip over. |
02-18-2020, 08:26 AM | #2 |
I think that's a good idea. I just did something similar on my X22R. I had the opposite issue. My kick stand hung too low when in the up position. Took a grinder to it and now it sit parallel to the ground.
