Go Back   ChinaRiders Forums > General > Riding > Sightings
Old 12-24-2019, 08:56 PM   #1
All in one   All in one is offline
All in one's Avatar
Powercore 2 & 3 Exhaust on 2019 Apollo DB 36 Deluxe 250's Street Legal supermoto
Installed Powercore 2 & 3 Exhaust on 2019 Apollo DB 36 Deluxe 250's Street Legal supermoto. Sounds ride like a different bike. Very nice. Almost 400 miles on each. I Havea black one & my brother has the orange. Glad we bought these. We did have since April, two Apollo rfz DB X 18 and one 2019 Apollo RFZ DB X 19... Have nothing but great results. We have grown up riding dirtbike's and have a Very clean 2001 YZ 426F. All tricked out brand new FMF exhaust on that. My bro basically renewed it. So been in the game sometime now... Anyway back on topic with these 250's. Or should I say 223's... Fun stuff. We mostly ride on the streets 95% of time. Wont be long until I get some tire's. The original still have plenty tread left but that'll be the next thing. Bought new Zipp battery's from Ebay $19.90 USD. I dont like using them battery's they send with bike's. Got Pro Taper SE 7/8 handlebars. Make sure to go over all your bolts. Ha.. Gotta few fenders, cant decide which one I like best yet. Polisport SM Line universal front fender looks to be it. Well see... I noticed they have lots of parts on Aliexpress.com website or app. App makes it easier. I installed two LED to inside very front corner's on front fairing's. Very bright.! Also purchased a little bigger diameter of a dime sized cheerios shaped neodymium magnetar snugly fit into oil filter/screen this that comes out when your changing your oil. It actually turns the screen and the spring slightly magnetic enough for it to also collect metal debris and shavings. I was shocked of the grime it collected. You should do that for sure. Found magnets at home depot or lowest. I'll ask my brother and let ya know for sure. Changed to oil quite few times during break in. Swapped carb out with a different PZ 30 30mm carb. And did away with chock and chock cable completely. Headlight works good with stock halogen bulb. Was thinking LED. Still trying to find a good bulb... speedometer was off 1-2 MPH, but was due to me going from 14 tooth sprocket to a 16 tooth sprocket. Stock foot peg's are heavy. Bought from ebay some CNC lighter weight wide foot pegs. Added CNC helmet hook. Had to grind down cover for front sprocket. Makes a big difference. The exhaust mount to head no issues. Had to heat up pipe with acetylene torch for plumbing etc.. for both exhaust's to get them to easily fit better. And with heat gun slowly heat up under where battery box is and push up with pipe to form while it was soft. Then cover small area with heat reflective coverage Wasn't to bad though. Used high temp gasket maker at connection's. Then waited until next day or 24 HR to install clamp. I use Valvoline 4 stroke motorcycle oil, 10 w 40. Seems to like it... 1100 mML for oil change. I got 200ML Pitcher from walmart.com for 8.66. Allows for precision on fluids. I'll add some pictures of a few apollo's. Oh and as for the RFZ 125cc, I basically made that street legal from scratch, Just how they come stock. Bought extra set of wheels with rim and in all and changed them with Michelin street tires. Gotta love it. Here's a few.Talk later.
Old 01-03-2020, 04:02 PM   #2
Audionut74   Audionut74 is offline
Great job so far!
Please Any links would be great for some of the parts you used in this build?
Sprockets?
Exhaust?
Carb?
These bikes aren't the easiest to find Designated parts that aren't Generic universal parts so most things will be a crap shoot if they will work or fit on this bike so any assistance would be greatly appreciated
Thanks
Brian
Old 01-04-2020, 10:58 PM   #3
All in one's Avatar
The exhaust is stock on the apollo 125cc.
This is for apollo dbx 18 125cc.
Link for front sprocket: https://rover.ebay.com/rover/0/0/0?m...2F233277451753
Rear sprocket: https://rover.ebay.com/rover/0/0/0?m...2F233311150996
carb : https://rover.ebay.com/rover/0/0/0?m...2F352663004512
Heres links for the apollo 250 deluxe.
Exhaust (single): https://a.aliexpress.com/s1msZNBw
Double exhaust: https://a.aliexpress.com/tnhkjBg4
Gasket set incase: https://a.aliexpress.com/DzHr1Mw4
Dipstick with magnet to catch metal shavings. Make sure you select one for honda: https://rover.ebay.com/rover/0/0/0?m...2F283231200840
Mirrors: https://rover.ebay.com/rover/0/0/0?m...2F254099283769
0-ring chain: https://rover.ebay.com/rover/0/0/0?m...2F293360188428
Battery: https://rover.ebay.com/rover/0/0/0?m...2F321365978281
Chain adjustment blocks: https://a.aliexpress.com/N6Z8nFLw
Another cool pair : https://a.aliexpress.com/pKLcYFBK
Have had no issues with anything. I have some videos on YouTube if your interested. Search "All in one apollo 250 deluxe exhaust upgrade"
Old 01-10-2020, 10:53 PM   #4
Cool thank you for the list
Any possible ideas on front or rear sprockets
For the 250?
Current bikes
2011 KTM 990SMR (Street Bike)
2011 KTM 990SMR (Track Bike)
2019 Wolf Rugby 150
Past Bikes
2007 KTM 950 SM
2013 KTM 690 Duke
2009 KTM 690 Duke
2009 Kawasaki KLR 650
2008 Yamaha WR250x (TURBO)
2007 BMW XMOTO650
2009 DUCATI Hypermotard 1100s
2012 GMW G150v (200cc custom)
Old 01-17-2020, 12:04 AM   #5
All in one's Avatar
Could not find a rear sprocket for apollo 250 deluxe. I did find a website call rebelsprockets.com. they can custom make any sprocket. They are only aluminum. I wanted a 35 or 36 tooth. I switched out stock 14 tooth sprocket to a 16 tooth for more top end. 450 miles on her thus far.. Just bought a pair a Dunlop Q3 plus's. Straight street tires. Gonna get another set of rims and put some pirelli scorpion SRT 50/50 tires on them so I can just quickly swap wheel's on the fly.. endless. Check me out on youtube..
Old 02-16-2020, 06:11 PM   #6
erodat13   erodat13 is offline
Do you have a link to the 16 tooth front sprocket you upgraded to?
Old 06-27-2023, 02:19 PM   #7
Firdouse   Firdouse is offline
Where can i get 17" wheels for apollo 250
Hey man, I wanna convert my apollo 250 that has 21" front and 18" rear wheels to a smaller wheel setup and slap on street tires for a supermoto. where can i find smaller wheels thatll be compatable for an apollo 250?
Old 01-05-2020, 01:34 PM   #8
wheelbender6's Avatar
Looks awesome.
apollo 250, apollo 250 rx, apollo db 36, apollo dbx 18, exhaust
