Ill try and find my documentation i made when i did my storm so you can add it, pretty sure it was the same as the brozz for the most part.
2020 Triumph Tiger 900 rally. 2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust. 2019 Taotao 110b boulder atv. The "arm breaker" lol 2007 Honda VTX 1300R. 1974 Suzuki tm125, work in progress 2001 Suzuki Drz 400s. |
It’s kinda logical and easy
I’ll add pics n my pros n cons for each |
Bross style:
Pros: Has a button to switch between odo & trip 24hr clock Fully program parameters like tire or mile or km pulse etc 7 color backlight options plus brightness control Easy fitment Hawk TBR7 and the like. Tire circumference 150-250cm adjustable by 1cm increments so accuracy isn’t a worry to many wheel sizes 4 magnetic pulse speed sensor better refresh rate Extra power output connection and plug for diy usb add on or other. Cons: Menu isn’t stacked as user friendly as it could be Button has a little red wire showing No volt meter no option to use fuel gauge as volt gauge TT Style - can use fuel as volt gauge, has digital volt display after trip meter and 7 color back light etc Last edited by NzBrakelathes; 04-05-2020 at 08:19 PM. |
Where can I buy? I bought the one that Motocheez uses and it doesnt work with the TBR7.
#6 | |
Same username You’ll see me pop up on his instagrams too |
#7 | |
How much for the speedometer? |
Bross style $65 as stated below.
yea i have no desire for an instagram account either....
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
#10 | |
You got this one and I know where they come from in China, I didn’t go with this factory for several reasons https://rover.ebay.com/rover/0/0/0?m...2F333227191734 How ever I did get a sample and I did fit it to a TBR7 and accuracy tho not perfect it was acceptable. It’s very important that you don’t mix your info and there for make others look bad etc. |
Bashan BSR DB-41H Enforcer - Bashans Hawk like bike I found out the pin out is the same as:
Bross TBR7 Sending a unit to the customer tomorrow and no doubt will get feed back soon Last edited by NzBrakelathes; 09-15-2019 at 09:00 PM. |
It's Bashan BSR DB-41H aka Enforcer/Hawk 2 etc... lol
Thanks for providing all those useful information it should make the upgrade process much easier! Writeup to come BSR Chronicles
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
#14 |
See it’s not hard at all
#15 |
Can you get a wheel speed sensor to make this work on the Magician?
