08-11-2019, 10:26 AM | #1 |
Stuck drain bolt. Help? - TaoTao Hellcat 125cc
Welp, first oil change and the piece of crap drain bolt is too damn tight. Already damaged it using vice grips after unsuccessfully unscrewing it using a regular wrench. Tried turning both left and right. My torque wrench didn't have sockets large enough. I might just go ahead siphon the oil out but what happens when I have to change the filter? Why can't manufacturers just use screws instead of stupid bolts. Thankfully this bike was only 1000$ practice bike so if it ends up ruined then it's not a huge money loss but I obviously want to take care of it and I can't just take it to a dealer unlike my Japanese scooter. Plz help...
08-11-2019, 11:30 AM | #2 |
Normally, the drain bolt on the horizontal engines is a 17mm metric head size, maybe you can try a 16mm 6-point socket tapped on with a hammer, just to remove it, and then dress up the 6 sides of the bolt until you can get another one.
It would be right-hand threads, BTW... |
08-12-2019, 09:16 PM | #3 |
You’ll need a stripped bolt socket. They work well. Notice it’s not a cheap noname brand cause if these fail it’s bad.
https://www.amazon.com/Irwin-Tools-5...gateway&sr=8-5 Tap it hard over the bad head so it takes a bite. Might have to gently lay the bike over to gain better axis. Times like this you’ll go from bad to worse if you rush or don’t make a calculated approach so work smart. Murphy’s law has a sense of humor I don’t like. Don’t toss the bolt so fast, use it to match up a replacement on length. Napa has a lot. Good luck.
08-13-2019, 05:32 PM | #4 |
Could you post a picture of what your working with?
Have you tired using a six point socket? |
08-13-2019, 07:48 PM | #5 |
You can try welding a nut to the bolt head and removing it that way ,and I have used a pipe wrench dozens of times on badly mangled crap customers have brought me ,but your first tool should always be a six point wrench or socket so it doesn’t make a mess in the first place .
bolt, change, drain, oil, stuck |
