08-05-2019, 08:44 PM | #1 |
TBR7 Digital Speedo Help Needed
I purchased a new digital speedo from hawkclusters@gmail.com. The product is beautiful and I am glad to have it. Instructions for installation are great for a Hawk 250 2016 and before, wire for wire. But I have a 2019 (newest version) TBR7, and the wiring is so very different.
I need help adapting the wiring from the Digital Speedo designed for the Hawk, to my TBR7. Have any of you made the adaption yet? If so, can your help? Do you know anything about the wiring of the the hawk or the TRB7 so I can work on an adaption myself? |
08-06-2019, 07:47 AM | #2 |
Follow the hawk instruction
I’ll have some direct fit Digital dashes soon and mine will be easier cause made directly to suit each bike You’ll need to de pin and repin |
08-06-2019, 09:14 AM | #3 |
As long as the connectors are compatible you just have to move the pins. Take a voltmeter and double check the color coding, unpin one side and make it match the other.
2020 Triumph Tiger 900 rally. 2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust. 2019 Taotao 110b boulder atv. The "arm breaker" lol 2007 Honda VTX 1300R. 1974 Suzuki tm125, work in progress 2001 Suzuki Drz 400s. |
08-06-2019, 10:29 AM | #4 |
colors all the same - pins might be in wrong place if Matt didn't change it on main connecting and you will need to depin the gear switch and use long wires etc
08-20-2019, 06:15 PM | #5 |
Same issue The wiring is for the hawk when I match the wires in the green/white plug all that shows up is a turn singnal indicator.
08-20-2019, 11:39 PM | #6 |
I have sold a few dozen to TBR Owners and they have made them work. I don't have access to a TBR anywhere near me to test fit. The pinout needs to be as below.
For your reference, from the back of hawk cluster plug where the wires go into the plug, Lock tab facing up it's: (lock tab) Lt Blue Orange Green Brown Yellow Dk Blue Grn/Red (empty) Black |
08-21-2019, 11:02 AM | #7 |
Here’s a few links to a better version
https://www.instagram.com/p/B1XqoFIH...d=crow5eefenez https://www.instagram.com/p/B1VZGVgH...=12r73d0bgls7a Pinned to your requirements and very flexible to accuracy for many wheels as it’s calibrated by you ti the tire circumference |
04-06-2020, 10:51 PM | #8 | |
04-09-2020, 02:25 PM | #10 |
Plz drop your IG name, have no way to follow without a Username |
05-05-2020, 12:40 PM | #11 |
Did anyone ever get some better instructions for this speedometer for a tbr7 I purchased on eBay, no instructions and setup for a hawk. There’s also a purple round terminal with the gear terminals I don’t know where to plug. Can anyone please help with instruction they know work? I tried another forum that lists the tbr7 but only got headlight and blinker to work :(
05-05-2020, 01:04 PM | #12 |
Did you get it from Nzbrakelathes on ebay? if so let him know, he will help you out. If not make some jumper wires and pin out each side, then repin the pig tails to match. If you have an el'cheapo test light it will be a bit simpler.
05-05-2020, 08:56 PM | #13 | |
05-05-2020, 01:22 PM | #14 |
I got it from a seller on eBay named alyanddrew. I messaged them but haven’t gotten anything back.
I was hoping to not have to test each pin, but I guess if I have to :( I’m just not sure where this purple peg terminal goes I’ll have to see what it lights up and look at the diagram of the bike. Thanks for the help! |
05-05-2020, 02:05 PM | #15 | |
