07-29-2019, 02:07 PM | #1 |
think Im done with grom clone
so far Ive had zero enjoyment of my tao tao hellcat.
It really just has an issue with the clutch not fully disengaging. First I bought a new clutch, which made no difference. Then, I bought a new clutch/engine cover which should have come with the clutch lever and clutch parts that are behind the chrome cover. I had to buy from Partskit since I can't find hellcat parts anywhere else. I've already had issues with their service before...so I emailed them to confirm that the cover comes with those misc clutch actuation parts. Basically I was told it comes as pictured. Well, the new cover arrived today, I excitedly unboxed.... Here is the pic on partskit's site...and the pic of what I received: |
07-29-2019, 07:38 PM | #2 |
Bummer!
07-29-2019, 08:37 PM | #3 |
Man, thats complete bs! And it looks scratched to hell too. WTF Partskit?
07-31-2019, 03:10 PM | #4 |
I wrote partskit an email stating the issue and that I wanted a refund.
I actually got a phone call, they said they would see if they have all the misc parts that were missing and if they do, they will send them...if they don't they will refund me. Will just have to wait and see how that turns out. |
07-31-2019, 09:50 PM | #5 | |
08-02-2019, 07:43 AM | #6 |
1. It looks like the dimpled bushing is inside your primary drive gear in the above picture, sometimes they get stuck due to oil stiction.
2. Usualy there is a collar next to the crank bearing, but are the rear drive teeth for the oil pump correctly lined up with the oil pump gear in the above pic? 3. You shouldn't use an impact gun when installing the clutch nut, it may cause binding against the crank bearing. |
08-02-2019, 11:01 AM | #7 | |
08-02-2019, 03:39 PM | #8 |
Talking to others on "clone army" forum, there seems to be a pattern of having a lot of problems with the Hellcat clones. I don't see as many complaints about the Vaders or Boom Lil Ducatti`s. Could be just a coincidence maybe.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
08-02-2019, 04:14 PM | #9 |
I went to TaotaoUSA, and emailed their service contact stating the issues Im having and that I was looking for exploded parts view.
They sent me a link to the partskit website for the hellcat |
08-02-2019, 06:39 PM | #10 |
Anyone know a way to bench test a clutch to see if it can disengage?
08-02-2019, 09:28 PM | #11 |
The only thing I could suggest to bench test it is with a piece of wood across the front and a small block of wood on the back where the primary gear goes, put it in a bench vise and slowly close the vise to compress the clutch springs. The whole basket should move inward, toward the back of the clutch. I'd want to take my time by slowly cranking the vise in, it probably won't go that far.
I'm inclined to believe that there is something missing on the shaft, not letting the clutch to be out far enough for the actuator arm "top hat" inside the cover, to push the basket in far enough to disengage. Did you get my PM from earlier today? |
08-04-2019, 11:34 PM | #12 |
I put the bike back together since I needed it out of the garage for a couple of days.
Did as suggested, used a wrench rather than impact gun to put the nut on for the clutch. Put everything else back on the same as it was before. Now it won't disengage at all! |
08-05-2019, 08:27 AM | #13 |
Are you getting any actuator arm movement up when you pull on the clutch lever at all? Did you adjust the actuator plate screw correctly, under the smaller engine cover?
08-15-2019, 10:26 AM | #14 |
Yeah... these frustrations you're having is pretty much par for course if you don't get one that is working.
The reason I recommend the Grom clones and not the SSR Razkull clones is you bypass a lot of the chinese suppliers by being able to use the Grom Plastics and parts. On that same note... there's no dealership for these Chinese bikes. Some are good, others not so much. Some have said that Taotao Hellcat is better quality, but it honestly seems like the Boom and the Icebear are a step up. The Taotao came out last. Feel like the Boom and Icebear had a lot more time getting things down pat. For your issues... Honestly... you may want to consider just getting a new 125cc pit bike engine. People swap the 190cc in and will sell their 125cc for a couple hundred. Or, if you have the budget for it, just throw the 190cc in and call it a day. That way you don't have to worry and mess with anything. |
07-18-2022, 05:09 AM | #15 |
I'm in the same boat
I purchased a tao tao hellcat. 4 months ago. haven't gotten to ride it yet. it didn't want to shift right out of the box. the company I purchased it and the extended warranty from. have abandoned me. I've replaced the clutch 3 times I've put the better carb on it to help with not wanting to start. but bottom line. I'm stuck I wanted to get the bike for transportation my car is broken down still. I'm just stuck. with a hunk of shit tao tao hellcat. can anyone help or give advice I'm broke too used all the money I had buying it. so I can't afford to do the 190cc swap. I'm running out of options and ideas.
