01-05-2007, 09:41 AM | #1 |
Roketa RSX200E, No Tach :~(
Hi guys, my RSX200E didn't come with a tach, but I would like to add one. My manual shows a tach port on the engine case. Do any of the other 200 enduros have a tach with this same engine so I could just buy their parts and put on my bike? Or, better yet, do ANY of the Roketa 200's have a tach?? I tried to find a universal motorcycle tach that was electric and I could just wire it off the coil, but I haven't found one??? Thanks for the help.
01-05-2007, 10:16 AM | #2 |
I think the Lifan 200 has a tach.
01-05-2007, 10:29 AM | #3 |
I believe the Lifan 200 does, but are they the same engine??
01-05-2007, 10:44 AM | #4 | |
The destination is merely a by-product of the journey. '06 KLR650 '06 XT225 '92 XT225 Serow ( MBD.... Multiple Bike Disease...) |
01-05-2007, 11:45 AM | #5 |
Just curious, why do you need a tach? I'm never looking down when I'm riding, except a glance to check my speed when I get up to speed. There's too much to look for ahead of me...like cagers!!
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
01-05-2007, 12:23 PM | #6 | |
01-05-2007, 02:49 PM | #7 | |
Re: Roketa RSX200E, No Tach :~(
http://www.accessoryinternational.co...egory_Code=Z1R
'20 RPS Magician 250 '06 Hensim (Tierra) DB150-2 '06 X-Treme 70cc pitbike '02 Kawasaki KX125 |
01-05-2007, 09:59 PM | #8 |
The tach on my bike is vacuum powered and runs to the carburetor. There isn't any mechanical port on the engine for a tach. I suspect that is the case for most of the Chinese motors.
Viva GY200 California Emissions Jialing/Chonging - Jesus Rules! |
01-05-2007, 10:11 PM | #9 | |
Fashby, your bike appears to be a bit of an anomaly compared to many of the others I've seen (catalytic converter?! EGR Valve! - that's not a China bike, it's a car!!).
Frostbite "The beatings will continue until moral improves" |
01-06-2007, 04:56 AM | #10 |
My bike has EGR valve and mechanical tacho, hard to decide if it looks like a anomaly or a car, must probably ask my wife
"Failure is always an option!" Qingqi QM200GY -06 |
01-06-2007, 08:05 AM | #11 |
Hi All
Ok lets clear this up, I just saw this post. The American Lifan 200GY-5 has an electronic tachometer, the 200GY-2 has a mechanical or cable operated tachometer. If you have a GY-5 the right engine cover Does Not have a tachometer cable port. If you have a GY-2 the right engine cover Does Have a tachometer cable port. The tachometer cable port is in the right engine case on the front of the cover. I can't say what other manufactures are doing with the tachometers. They may be set up like this they may not be. There are only two ways to run a tachometer on any vehicle or engine, electronically or mechanically. There are aftermarket tachometers that you can attach a probe around the spark plug wire to run the tachometer, or you can purchase one that will run from a cable for that particular engine. There is no such thing as a vacuum operated tachometer. A tachometer can not tell engine revolution from vacuum. There are two things you can do checking vacuum...check how the valves are operating or synchronize multi-cylinder engine carburetors. Ride Wild and Fly Like an Eagle! 8O Bruce
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
01-06-2007, 07:16 PM | #12 | ||
01-06-2007, 08:26 PM | #13 | |
