Old 07-10-2018, 12:01 PM   #1
gaborbelan   gaborbelan is offline
Rx3 Front break rotor
Hi guys, I would like to ask if somebody tried some similar front break rotor for rx3? I checked on the CSC website and their shipping are so expensive,I would like to know if its some similar parts for that. I live in Europe.
Cheers
Gabor
Old 07-10-2018, 03:19 PM   #2
Yes....and I need to order one myself. I believe it's the Suzuki Bergman rotor. I had it stashed in my Amazon list but like a fool, deleted it.
I got a replacement for my stock one from CSC on warranty but it started chattering and giving uneven braking last week.
Here's what Spud had to say:
I have verified the EBC, MD929D brake rotor is a perfect fit for the front wheel of the Zongshen RX3. This brake rotor fits the following motorcycles.
Front Wheel
98-02, Suzuki Bergman 250
99-02, Suzuki Bergman 400
You will also need the bolts:
https://www.rockymountainatvmc.com/p...6153509&ref=cj
It's also a full floating rotor. A vast improvement over the stocker.
Old 07-10-2018, 05:01 PM   #3
Good luck with the replacement rotors. I followed a recommendation from this list for what was supposed to be a drop in replacement. It's darn close but the bolt circle diameter is about 2mm off from what the RX3 requires. One solution is to drill slightly larger holes and then countersink slightly larger countersinks...but now you have an issue with getting the rotor perfectly centered. If you get the Bergman spec rotors and they actually work, please let us know. Floating rotors would be a real improvement!
Old 07-10-2018, 05:29 PM   #4
I think Spud ran one on his RX3 without issue. I'll have to search it out.
EDIT: FOUND IT!!!
http://www.chinariders.net/showthread.php?t=18547
Old 07-10-2018, 08:33 PM   #5
NzBrakelathes's Avatar
Cheers
Gabor
I can supply a stock rotor or I am making an upgrade set
I live in China
Old 07-10-2018, 08:35 PM   #6
This is my RX3 but I have the Alloy wheel and differnt hole patter - I am trying to make a set up the same for the spoked wheel but so far no proper fitting disc - That is all I am stuck on.
Old 07-12-2018, 05:52 AM   #7
NoVa Rider   NoVa Rider is offline
I also found that the Burgman rotor was not an exact fit for the front stock RX3 wheel. I made one fit by carefully walking the mounting bolts into place but this stresses the hub and I would not recommend doing it. Odd that there are two rotor sizes that are so close. So far however the only exact fit rotors I have found are the OEM or the larger rotor CSC sells in their large brake rotor kit.
Old 07-12-2018, 09:49 AM   #8
I dug up the rotor I bought, that was a close fit but not exact, and found the following numbers:
PXCKBA61328
4162
This is an EBC rotor, not sure what bikes it is supposed to fit but it had been reported to be a drop-in replacement for the RX3.
Old 08-09-2018, 08:53 PM   #9
I have a 320mm rotor sample coming very soon I am told.
Hold your fire wait wait as I hope soon enough to be able to offer a 320mm rotor and 4 piston caliper set up for the spoked wheel bikes
Old 09-26-2019, 11:24 PM   #10
Gaijin   Gaijin is offline
Isn't this what you want?
https://www.cscmotorcycles.com/check...t-installation
Old 09-27-2019, 09:37 AM   #11
Juanro   Juanro is offline
Juanro's Avatar
Originally Posted by Gaijin View Post
That is a nice looking (and surely, working) brake update kit, but 1) it's not a floating disc, just oversized and 2) price is prohibitive for me in Argentina
