07-04-2018, 09:47 AM | #1 |
Do it right the first time!
Replaced a bike tube for the first time in 1961. 56 years later for the first time ruined a new tube during install. First time for everything. Ordered a 100/90-19 tube from American Mototire and they sent a 120 to 140 tube and it was a bit clumsy. Went to Abernathy's yesterday and requested a 100/90-19 tube. Got home and noticed the numbers on the box were 2.75 to 3.00, which converts to 80 to 90 cross section. Too small. No wonder I don't like doing business with Abernathy's. Again. Now I have a really good reason to head out for a couple hundred miles of country 2-lanes to find a tube.
Then enough miles to change back to synthetic oil. |
07-09-2018, 09:13 AM | #2 |
It's really easily done. I didn't for the first three changes on my bike, then on the fourth I managed it.
Overconfident with the tyre irons, not enough pressure in the tube to keep it pinching, and a lot of time wasted. It happens! |
07-09-2018, 09:19 AM | #3 |
Been there, done that.
07-09-2018, 10:13 AM | #4 |
I can always tell when I'll pinch a tube because the install went perfectly. Those are usually the ones I mess up. If I fight with it for hours, never a problem.
07-09-2018, 10:48 AM | #5 | |
"Well, that was easy." *HISSSSSSssssssssssssssssssssssssssss* DAMMIT |
07-09-2018, 01:40 PM | #6 |
Well, now, that sounds familiar.
07-09-2018, 02:47 PM | #7 |
I noticed the aftermarket tubes seem a little more forgiving than the stock ones
Peace and Zong Life
07-10-2018, 01:29 AM | #8 |
Hope so. Ordered a new 100/90-19 Kenda from americanmototire.com, the tube they sent was a French heavy duty for 120 to 140. It was a bear and I killed it. Accidently. Drove to the nearest dealer and asked for a 100/90-19, got home with a Japanese 2.75/3.00-19. Figured I'd stuff it in and ride over for the correct tube the next day. It committed hari kari, 2 inch (5cm) split belly the next morning. Drove to the local dealer again and specified a Chinese 100/90-19. Went in easy, still holding air.
