Old 05-30-2018, 03:58 PM   #1
wlfpck   wlfpck is offline
Grom Clone Speedometer Replacement and Wiring Diagram for Aftermarket
So... needed to replace the speedometer on my Icebear Fuerza. Had called the dealership I got my motorcycle from and they called the distributor (Icebear) and was quoted about $100 for the speedometer.
Figured this info would be useful to everyone else here...
Didn't want to shell out that much and ended up finding this on Amazon (with Prime shipping )
https://www.amazon.com/Samdo-Univers...do+speedometer
Bolts right up and hooks up to the existing wire harness. Total of 3 plugs.
Below is the wiring diagram (had to do a bit of Google searching) in case someone wants to use a different speedometer.
Old 07-09-2018, 08:53 PM   #2
J-May   J-May is offline
J-May's Avatar
Send a message via ICQ to J-May
Have you installed this yet? My speedometer is wayyy off due to the incorrect tire size being used. I am trying to program the correct size in so that I'm not ringing up hundreds of extra miles. But I have been unsuccessful in programming a new size in. Any help would be appreciated. Currently my true gps speed of 55mph is displayed as between 73-75mph.
Old 07-09-2018, 10:59 PM   #3
J-May's Avatar
Just figured this out for the stock factory dash unit.
Made a post for changing the wheel size which can be found here http://www.chinariders.net/showthread.php?t=21714
Old 07-10-2018, 05:55 AM   #4
That's an awesome " How To " post J-May., thanks for that !
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 07-11-2018, 02:14 PM   #5
I've installed it... but I did not get it programmed or anything like that. The speedo was off by like 5 mph (from GPS) from the factory so I didn't think too much of it.
But nice job on the write up. That should help a bunch of people out.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 09-17-2018, 03:39 PM   #6
pochito413   pochito413 is offline
Did your rpm gauge work off of the stock tach wire. Mounting mines and the it didnt work. Directions say i must tap it into the triggle wire. Read online that i must wire directly to the pulse generator. Unsure if its the same thing.
The nuetral light also does not shit off in any gear. It marks the other gear but the N stays lit. Not a short in the wires as i ran the wire all the way back and jumped it out with a new wire to both the connectors it splits into and had the same affect
Old 09-18-2018, 01:33 PM   #7
I just plugged the new one in and it worked for me.
2020 Honda Grom
Old 09-18-2018, 08:32 PM   #8
Figured it out. Had some wires that had some copper strands hanging out and shorting them out. Fixed them and it fixed my issue with the nuetral light and it nor reading rpms. Also spliced into the red wire that goes into the ignition switch to provide a constant power supply to the cluster so it saves its programming. Now just need to mount the speed sensor and i will be all set with it. Am thinking of making some knd of bracket, although it was recommended to just drill and mount it on the fork guard
