10-07-2017, 08:11 AM | #1 |
Brand new performance exhaust for hawk 250
Brand new performance exhaust for hawk 250. $150
06-18-2018, 10:42 AM | #2 |
Would this fit the storm 250 as well? I just got a slip on but for $60 more I could have just gotten something like this
06-20-2018, 09:23 AM | #4 |
That is not a cat in the head pipe, that is an expansion chamber to smooth the exhaust pulses to make it flow better
06-18-2018, 04:53 PM | #5 |
Oh ok than slip on it is!
06-19-2018, 08:32 AM | #6 |
You can get the complete exhaust system for under $100.
https://www.ebay.com/itm/142353476469?rmvSB=true
08-18-2018, 10:21 PM | #7 |
is this the same?
https://www.ebay.com/itm/Aluminum-Mu...r/322329718684 |
08-19-2018, 12:41 AM | #8 |
Yes, It's been proven to work on the Hawk the Brozz and the Storm, you need to modify the mounting flange. Either drill it out (hardened steel), or use a grinder and slot the mount holes (easier) to fit a larger bolt pattern on all three of the bikes.
Visit me on YouTube at "Project Next"! https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber 2017 Bashan Storm Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter. |
08-19-2018, 08:43 AM | #9 | |
Yes, it's the same exhaust. The only difference is the muffler is a shinier chrome/aluminum color vs. the gray on the one pictured at the top of this thread.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
