10-02-2017, 12:21 PM | #1 |
Hawk 250 Nuetral & Transmission Problem
I just recently bought a Hawk 250 and fixed it up and then when I went to ride it the neutral light was working then it shut off and it still goes into 1st gear but it won't go into 2nd. I can get it up to 25 MPH in 1st then try to shift to 2nd and it won't. Any ideas on what the problem could be? It has less than 500 miles. Thanks
10-02-2017, 01:23 PM | #3 |
Can you shift through the gears when its not running? You may just need to adjust the play in the clutch. You want almost no slack in the clutch lever. Only about an 1/8" of play.
10-02-2017, 02:10 PM | #4 |
When it's not running I can put it into first and second because the bike will be rolling until I put it into gear and it stops, since it's in gear. But when I ride it it doesn't want to go into 2nd. I got it to slip into 2nd once and then it popped back out into neutral. When I get off work I'll try to get a video
10-02-2017, 02:28 PM | #5 | |
10-02-2017, 03:01 PM | #6 |
Here's a tutorial on clutch adjustment. http://www.cscmotorcycles.com/Articles.asp?ID=298 If this doesn't work it could be in the shifting mechanism itself.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-02-2017 at 03:41 PM. |
10-02-2017, 03:46 PM | #7 |
Thanks again could that also be why it will slip out of first sometimes?
10-02-2017, 04:17 PM | #8 |
If it's slipping out of 1st gear and there is nothing externally obstructing movement of the shifter then is could be something internal such as a damaged drum stopper plate, Drum stopper arm or shifting forks. But with less than 500 miles it may not be the case. Try all the other suggestions first and report back. Then we can go into it further.
10-02-2017, 07:38 PM | #9 |
That screams out clutch adjustment, but I'm also concerned with it not going into 2nd, because you CAN shift without the clutch (I'm not saying it's a good idea LOL). Perhaps you have a bad shift pawl, or drum. Tinker with it some more and let us know!
10-02-2017, 07:45 PM | #10 |
This is weird I was riding it and from a standstill if I put it in 1st it grinds really bad and won't let me but if I start in 2nd it takes off just like if I was in 1st. But then I'll be slowing down and have to put it into first to keep it from stalling the only thing is that it won't go past 2nd now. Does that make sense?
10-02-2017, 08:05 PM | #11 | |
10-02-2017, 08:57 PM | #12 | |
10-02-2017, 10:24 PM | #13 |
1st thing I notice is that the shift lever is hitting the housing. Remove the lever and rotate it counter clockwise 1 groove on the spline. It's not shifting all the way to 2nd gear. The shift lever is bent in to far and really should clear the housing.
10-02-2017, 10:40 PM | #14 |
After reading the other post. If its still pulling with the clutch lever pulled Your clutch needs to be adjusted. You shouldn't have more than an 1/8 inch of play in the lever.
10-02-2017, 10:42 PM | #15 |
Yes! The shift lever is hitting the cases on the up shift. It is not allowing the ratchet and pawls to go through their cycle so he can shift to the next higher gear. It may be only partally engaging second gear. Don't ride it like that, it will wear the dog clutches in the transmission....ARH
enduro, hawk 250 |
