07-12-2017, 09:10 PM | #1 |
2017 Bashan Enforcer
So I am really new to CR forum to start out with.
I actually intended to buy a Honda CRF250L but after talking to my bank I was actually going to need to put down the same amount that the Enforcer cost and have payments for the next 2 years.....screw that. I was debating the Hawk, the Brozz and the Enforcer but liked the Enforcer best so I ordered it today.Most of all because it seems to be really easy to register and http://www.apscusa.com has great reviews. There is a huge following for the Hawk and they look almost identical so I have a few questions for the experts. Here we go: 1.How interchangeable are the parts? I haven't been able to find what carb the Enforcer has, I am assuming something similar to the Hawk. I plan on adding some after market parts and mods. Air box, exhaust, jets......and most of all the digital speedo. 2. Hawk hand guards...can they be used? 3.What are the bikes based off of? I have heard Honda but year and make would be great. May be an easy way to get parts that need little retro fitting like an FMF exhaust. Anyone else have this bike that has some helpful info? |
07-12-2017, 09:46 PM | #2 |
Welcome aboard !
07-13-2017, 10:58 AM | #3 | |
1- Most parts on most Hondoids are interchangeable. Brakes, levers, many of the motors, etc.... They're readily available on A,azon, EBay, Tao Bao, etc... 2- You can fit most handguards that fit 7/8" bars. 3- The engines are CG Honda clones, originally 125's. Honda never imported in to the US but most everywhere else. It's a VERY reliable motor. The bike/frame itself is the latest greatest coming out of China. It's the newest generation of their stuff. I'm not sure if it's based off of anything. Someone else can chime in.
07-13-2017, 02:21 PM | #4 |
The Enforcer is a pretty good stock bike. This is what I did to mine.
Ebay exhaust: Just need to work the pipe around the airbox. Mark some points and bend and hammer so that there is a 3/4 inch gap. I used a little heat wrap like MOTOCHEEZ Carb: The stock jet on the Enforcer is a 105. I upgraded to a 110 and looking to a 115. They just screw in and out. There are tons of threads with links to Amazon and Ebay Tubes: Highly suggest ordering some heavy duty tubes. The stock tubes are as thin as bicycle tubes and the seems will split. LED bulbs: Look for replacement bulbs to ease the charging system. Gearing: The gearing is already upgraded to a smaller rear sprocket. |
07-13-2017, 03:00 PM | #5 |
Wow thanks for the fast responses. I am hoping to have the bike by the end of next week. I called the dealer that is listed in Tennessee and he said it takes two to three days to process and a couple days to ship so hopefully those are worst case scenario numbers and come sooner. Looking forward to this bike.
07-13-2017, 03:53 PM | #6 |
So with those questions out of the way...
What fluids should I change before riding? I have heard a lot of people on here say to change the brake fluid, fork fluid, and the oil. Any recommendations on type or brand for all three? |
07-13-2017, 05:19 PM | #7 | |
Brake fluid, DOT 3 or DOT 4. Either will work fine, but most people opt for DOT 4. Both can be found at the parts store. Forks - there are two mentalities here. Many use ATF, and even OE Manufacturers for the longest time would use ATF and recommend it in their forks. I suggest a good name brand fork oil. Purpose built fork oil has anti-foaming agents to help keep the fluid stable during operation. Brand wise, there are a lot of good choices. Maxima, Valvoline, Lucas, Pro Honda, PJ1, Yamaha, etc. Personally, I love PJ1 or Pro Honda, but they will all do the job. Depending on your weight and personal preference you can run different weights to tailor how the bike behaves. I run a 15wt oil in mine, and it is usually a good starting point since it sits right in the middle of the scale. Engine oil - everybody has opinions on what is best, so take your pick. As long as the oil is JASO rated oil for use with wet clutches. I use Shell Rotella T4 15w-40 in both of my bikes. It's a great proven oil, it's affordable, and it can be found damn near everywhere. You can buy a 4 quart jug of it from Wal Mart for about 13 bucks, and a typical CG250 engine takes about 1.5 quarts to get to the middle of the sight glass with the bike vertical, so 2 jugs = 6 oil changes for $26 Also, make sure to set the valve clearances before running the engine. They will come with 0 lash adjustment, and should be set to .003, plus or minus .001. Many people run .003 intake and .004 exhaust, but you can set them both the same.
07-22-2017, 03:24 PM | #9 |
Well, I am still waiting for the Enforcer to arrive. I was hoping www.apscusa.com had time to sort out the issues on their delivery time but I guess they have not. I have heard a lot of complaints lately but I was hoping it was figured out. After multiple phone calls and several estimates I am now being told it will not ship before the end of next week.
I am more patient than my wife....but I am getting my butt chewed because there is $1500 missing from my account and nothing to show for it. Really need the China bike gods to move this along...tired of being told "shoulda bought the Honda" lol. So much for 2-3 days to process then ship. |
07-22-2017, 05:42 PM | #10 |
Sorry to hear they STILL don't have their act in order!? When Kandi USA was distributing the Bashan Brozz and Shark, I referred several people to my friend Alan from Excalibur Motorsports, but Kandi only ordered a few containers of those bikes, and they ran out; Alan does not deal with the company that distributes the Enforcer and Storm, so those are left to the flaky dealers, unfortunately.
07-25-2017, 11:25 AM | #11 | |
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
07-27-2017, 07:30 PM | #12 |
Did get your enforcer yet? I've been waiting since May
07-28-2017, 10:48 AM | #13 |
No I have not received it and I talked to them again on Wednesday. I asked the guy how they can advertise 2-3 days processing yet its been 3 weeks and has not shipped. When asked how they can advertise its in stock but they keep saying the are still waiting on the shipper the guy got pretty nasty and defensive.
He then went on to tell me that there are people that have been waiting 90 plus days! How is that possible if they are "in stock"? |
07-28-2017, 11:14 AM | #14 | |
So let's say I am dealer A. I make a retail distribution deal with wholesaler/importer X, who gives me a list of the bikes he has in containers either on hand or on the way from China on a ship. I list them as 'in stock' on my website, based on what the wholesaler has told me. Customer Z buys a bike from me, and I place the drop-ship order to my wholesaler/importer. They send the order to the warehouse, which attempts to fulfill it. If the bike ordered is indeed in stock, then they make a deal with a carrier to pick up and deliver. Because they deal with price points, they shop for the best deal possible. It may take awhile for a carrier to become available. Or, the bike might not be in stock after all or it might have been in stock at the time the dealer put the bike on his website, but then it was sold and he didn't get the word, or if he did, he didn't update his website quickly. Or it could be that the dealer is a guy making a quick buck on a low-margin item, and that he has little or no concern for what happens after he gets paid. He is not planning to be around for decades. He has no retail showroom, no inventory, probably not many employees, if any at all. He's literally a one-man show with a website and a sketchy business plan. I'm sure there are lots of other reasons. However, in my opinion, if you go into one of these transactions without doing your due diligence and understanding what you're getting into, you're likely to get burned. Some other person posting that they bought from XYZ dealer and their bike arrived in 3 days and in perfect condition and they got the MSO or other paperwork a couple days after that, and they mistake *anecdotal evidence* for actual proof that this is the typical way the dealer responds. It might be - it might not be. The purchaser has to do their homework. "Do you have the item in stock" is a valid question, and you'd think it has an easy answer. However, a better question might be "Do you stock the item yourself and is it physically in your possession?" The seller might still lie - can't stop bad people from telling tales - but it pins them down; the can't hedge their words, it's either yes or no. Best of luck, I hope everything works out well for you. |
07-31-2017, 10:49 PM | #15 |
Well, still no notice the Enforcer has been shipped. I was told on Friday that they were going to have them out by the end of the day. This right here is why China bikes cant take hold in the U.S.. Its not a matter of people doing the work, its the fact you cant trust any of these company's to stand by their word.
There are no dealer checks and balances.You pull this at Honda and at least you know you still have options to call. I am seriously having doubts that I will ever see my $1500 without going to court and even then I am sure I will never see it. Sucks.... |
bashan, enforcer |
