03-17-2017, 10:22 PM | #1 |
Hawk lightbulbs
I had a turn signal bulb go out. I tried three local autoparts stores even a cycle shop and they did not have the bulb. Yay for Ebay! I got ten of these for ten bucks. I tried one and they do work! The glass shape is a little different, but they work as normal. Remember, the pins on these bulbs are off set of each other. Also, the front halogen headlamp is a HS1 35/35 watt bulb. There again, no local store in my area had that low of a wattage bulb. They had HS3 and HS4 I may go LED, but this is on the cheap right now.
03-17-2017, 11:49 PM | #2 |
BAU15s vs BA15s (1156)
Pliers (files...) & solder iron is ur new friend if can't find the offset BAU15s locally === HS1 vs H4: https://en.wikipedia.org/wiki/User:KDS4444/HS1_bulb | https://translate.google.com/transla...3D1&edit-text=
03-18-2017, 01:31 PM | #3 | |
03-28-2017, 10:04 AM | #4 |
Hawk brake light bulbs
I found these online for the hawk
