11-23-2016, 04:01 PM | #1 |
Hawk License Plate mount
OK all you hawksters... how pray-tell did you mount your license plate? The bolt holes don't line up with my newly minted VT plate so I tried to mount it with that bracket pinching it and that little hook thingy.... It was a little too loose for my liking.
11-23-2016, 04:15 PM | #2 |
I just elongated the slots on the bracket maybe an 1/8" on each side.
11-23-2016, 04:23 PM | #3 |
I seem to remember this issue coming up before. I can't remember if they just redrilled the holes in the mount, or bolted a piece of 1/8th inch aluminum over the whole mount, with holes drilled in the right places for the plate bolts to go.
11-23-2016, 04:38 PM | #4 |
before I broke the drill I wanted to make sure there wasn't a trick.
Thanks all! |
11-23-2016, 09:01 PM | #5 |
yep got mine mounted sideways across the diagonals till i get around to it
11-24-2016, 01:42 AM | #6 |
Yep, that's how my buddy did it, even though I think it looks wonkey. I used the metal ties that came in the crate with black coating and twisted them tight with pliers.
11-25-2016, 05:36 PM | #7 |
This is what I did.
11-25-2016, 01:11 AM | #9 |
I removed the bracket and drilled holes in the rear fender (left and right of the holes that went to the bracket) that line up with the license plate.
See post #24 http://www.chinariders.net/showthrea...t=16636&page=2 Post #46 in the same thread is a closeup of the right side. |
11-25-2016, 04:29 PM | #10 | |
