Old 08-27-2016, 12:03 PM   #1
zanoknight   zanoknight is offline
zanoknight's Avatar
Battery Recommendations?
So I woke up today to find myself a dead battery (sigh) it lasted me about 3 years so i can't complain. Now it's time to buy a new one. Anyone order theirs online? I've been looking all over and i'm overwhelmed by the amount of choices. My owner manual recommends 12v at 4 or 5 ah. Can I get a higher ah? like a 12v 10ah? I like having the security on those cold winter days.
Any info would be awesome!
Old 08-27-2016, 02:00 PM   #2
The ah reference can be interpreted as volume. As you look at the box that the battery fits in, you can see that capacity is limited to what fits in the space. If a 5ah battery is a snug fit in the box, you can't fit anything larger. That mostly applies to lead acid batteries.
These are very generalized comments, as the fancier LiFePO4 batteries can spin the motor over faster despite a smaller package. They are much more expensive and mustn't be allowed to run low.
My favourite is the BikeMaster Platinum II MS12-4L-A AGM battery. It is a good balance between cost, capacity and longevity. It is available from several sources, and I either bought mine at Rocky Mountain or Bike Bandit (can't recall which). That was in 2013, and it is still going strong. AGM is nice because it doesn't spill and rust the frame and battery box.
Old 08-27-2016, 02:23 PM   #3
zanoknight's Avatar
thanks for the reply!
I know I can fit a decent size battery, it just cant be tall. it has to be a rectangle like the one you recommended. The one I have installed now barely fits. I actually might consider it too small. that's why I was wondering if the ah will affect the system in anyway (in a negative way)
Old 08-27-2016, 03:13 PM   #4
Adjuster's Avatar
My local WalMarts now have a very good selection of AGM small engine batteries. Can't beat the convenience, cost and easy return policy if there is a problem. Take your battery box dimensions to the store with you and purchase the largest battery that will fit your box. You also need to make sure the positive negative terminals are on matching sides of the batteries.
Old 08-27-2016, 06:51 PM   #5
X2. I bought a Walmart AGM battery last year, and it's still going strong in a quad.
Old 08-27-2016, 07:19 PM   #6
pete   pete is offline
pete's Avatar
The XT660 got 8 years out of the Yuasa..
the TTR250 got 6 years out of the Yuasa..
Yuasa ain't cheap but they are possably best
of the AGM battreys...
Prob why Yamaha use Yuasa as standard...
Motobatts are quite good ..."yellow ones"
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-28-2016, 03:47 AM   #7
humanbeing's Avatar
Are u talking that Xingfu in http://www.chinariders.net/showthread.php?t=16012
Xingfu used had thai investor, their early 125 (pre '93) had Honda parts... Engine from old model looks as Honda (small-fin barrel/ Kick ONLY) http://blog.sina.com.cn/s/blog_5fffe9ed01019jp3.html YB3L-A is suitable for these | The E-strart version is somthing similar to Hawk ~6.5Ah
You will find it after reading http://www.chinariders.net/showthread.php?t=16520 | http://www.chinariders.net/showthrea...ghlight=chrome | http://www.yuasabatteries.com/pdfs/Y..._Apps_2015.pdf
Old 08-29-2016, 01:55 AM   #8
zanoknight's Avatar
Xingfu used had thai investor, their early 125 (pre '93) had Honda parts... Engine from old model looks as Honda (small-fin barrel/ Kick ONLY) http://www.chinariders.net/showthread.php?t=16012 YB3L-A is suitable for these | The E-strart version is somthing similar to Hawk ~6.5Ah
Thank you so much for the info! It's so hard to find any info on my motorcycle. Yes it is a XingFu, It's from 2001 (according to my title). If you have any more info I would greatly appreciate it. I can't find a wiring diagram anywhere. whoever had this bike before me did an awful job taking care of it. They rewired it all wrong and I have slowly put it back together.
Old 08-29-2016, 08:59 AM   #9
humanbeing's Avatar
Originally Posted by zanoknight View Post
...They rewired it all wrong and I have slowly put it back together.
Rewire is easier if divide in groups: E-start | IGN | Signal | Charging & lights (front/ rear)
http://www.chinariders.net/showpost....45&postcount=2
Honda color code is usable in chonda & other far east imports: Taiwanese (Kymco/ SYM & copycats...) | Korean (Daelim)
Red: battery's + to lock s/w
Pink: Stator to rec/reg
Blue: hi-beam
Green: - & ground
Black: the + after lock s/w
White: Charging output, Lo-beam
Yellow: Headlight's power source (AC headlight / half-wave system mostly) | charging input (rec)
Grey: flasher to indicating s/w
Orange: Indicating s/w to LEFT's
Sky blue:Indicating s/w to RIGHT's
light brown: lights in the Gauge
Brown/white: front position light
Light green horn to it's switch
Red / white: rectifier output (Voltage sampling wire in 5-wire rec...)
black / white: CDI to lock switch (IGN OFF) ***often means grounded/- ***
blue / white: Trigger signal (Blue / yellow...)
Orange / White: left indicator inside gauge
Blue / white: right indicator inside gauge
Yellow / white: fuel level gauge to float s/w
Black / red: From exciter coil to CDI ***AC-cdi's power source***
Light green / red: neutral s/w to it's light bulb
black / yellow: CDI (output) to ign coil
Green / yellow: brake s/w to brake lights
Yellow / red: For solenoid's +
Old 08-29-2016, 03:31 PM   #10
zanoknight's Avatar
thank you! everything you gave me was super helpful!
Old 08-29-2016, 01:56 AM   #11
zanoknight's Avatar
Thanks everyone for your inputs! I really appreciate it.
Old 08-30-2016, 11:32 PM   #12
hertz9753's Avatar
http://www.ebay.com/itm/Battery-Tend...-/232037249826?
http://www.ebay.com/itm/Deltran-Batt...843919?vxp=mtr
That is what I use. The battery was $69.18 and the charger was $29.11 and I also got a small discount when I purchased them together. The battery was smaller that the stock battery but came with foam blocks and tape on one side to make it snug.
Old 08-31-2016, 12:40 AM   #13
humanbeing's Avatar
Originally Posted by hertz9753 View Post
... I also got a small discount when I purchased them together...
Compare & find the best deal in http://www.nextag.com
btw. Most smart RC charger had LiFePO4 mode. M/c battery is just a 4-cell pack...
Old 08-31-2016, 01:00 AM   #14
Azhule   Azhule is offline
The foam blocks wasn't enough for our bike/battery box design... so I just cut a small piece off a "Pool Noodle" to make a nice and snug fitting "Foam Spacer" for the Lithium battery on our Bashan
Old 08-31-2016, 01:34 AM   #15
hertz9753's Avatar
That is what I bought and my Hawk weighs about three pounds lighter.
With the battery a exhaust changes I can lift the back of my Hawk off the ground and I am not a big guy. I only weigh about 45 pounds more than Az.
battery, dead battery, online
