08-10-2016, 09:42 PM | #1 |
Gear Indicators
Okay China Riders have a question. Where is the sending unit for the gear indicator located? Is it in the motor housing? I'll be home later this week and was going to see if I could get that indicator light working. So any input before I get started would be appreciated.
2005 Kazuma Cheetah 200 (Swamp Thing) |
08-10-2016, 10:10 PM | #2 |
Found this pic for starters. That s front sprocket so you can see indicator wires leads into the transmission case . Hoping to find a pic of the actual indicator disk mounted in position
08-10-2016, 10:23 PM | #3 |
The gear indicator on my brand new Bashan also went south so I could really use this info. It shows a 0 in neutral or the left line of the 0 goes out in any gear?
08-10-2016, 10:34 PM | #4 | |
Search images with something like " china bike led gear indicator "on google, eBay or Amazon to match it up
08-10-2016, 10:25 PM | #5 |
Sensor indicator for example
08-10-2016, 10:48 PM | #6 |
Oh cool thanks BB....
08-11-2016, 01:08 AM | #7 |
Very often the wire is simply trapped by the cover. Remove the cover, reposition the wire and see if joy results.
08-11-2016, 01:43 AM | #8 |
The problem could be in the connection as well. Often the prongs will fail or are never correct on inside the plastic connection. Sometimes you have one loose from the start and then another one or several come loose later on with vibrations. You can normally pull the connection apart and it will become obvious if there is a loose terminal. From there you just have to get a precision screwdriver or something small to push out the fins on the terminal. It's always good to make sure there is a little slack in the cables as well.
08-11-2016, 12:18 PM | #9 |
Cool guys thanks, gives me something to mess with this week end.
08-11-2016, 08:58 PM | #10 |
Weekend starts at 1201 pm CHARGE !
08-11-2016, 11:27 PM | #12 |
The led display looks pretty rough, wonder if I can test it some how? I'll have to play around with it.
08-12-2016, 03:43 AM | #13 | |
The typical 5-gear had 7 wires [1]+ & [6]- N(0)/1 to 5 If it works OK, then find the ??? in the engine side (s/w unit | black thingy as #4)
