05-21-2016, 03:07 PM | #1 |
skid plate - uh oh
So. While I was doing my oil change today, I took the skidplate off and while doing so, the front mounting bracket also came off
here you can see where it was mounted to the bike: I'm thinking my options are: 1) Leave the skidplate off 2) Find someone to weld the bracket back on 3) Grind off the other brakets and install the beefier skid plate *sigh* as for the oil change, it went smoothly, though with the center stand deployed, I could not get my oil pan exactly under the drain hole so I got oil all over the floor *again*. The oil looked dark to me, and there was a fair bit of sludgy stuff on the drain plug, but didn't notice any sizeable chunks. Oil strainers looked pretty much clean of debris, there may have been one or two bits of not sure what on the oil strainers, but I was unable to identify what they were. This was only my 2nd oil change at 1000 miles but I'm hoping to churn through the next 1000 miles much faster now that I am more comfortable riding. |
05-21-2016, 03:14 PM | #2 |
Replace it with the CSC aluminum skid. Half the work is already done! Click on my blog for install pics.
2016 CSC RX3 Ginger Edition Check out my blog here: https://www.facebook.com/My-CSC-Zong...0302595973417/ |
05-22-2016, 11:55 AM | #3 |
Similar thing happened to me Sprite, except that only half of the bracket broke off. I used an appropriately sized hose clamp, in your case use 2, and it's stayed on for thousands of miles. I can post a pic if you need.
George 2016 CanAm Spyder F3-L |
05-22-2016, 12:06 PM | #4 |
Thanks George, if you could post a photo so I can ensure what I'm visualizing is correct I'd very much appreciate it.
05-22-2016, 12:30 PM | #5 |
Hope this works for you Sprite. Mine broke at the 90° angle next to the bolt hole.
05-21-2016, 05:02 PM | #6 |
I would just leave it off unless you intend to take it on any dirt. The aluminum skid plate is very nice and keeps the front of the engine clean, but it's overkill for most riders.
05-21-2016, 07:55 PM | #7 |
I will probably leave it off for now but I intend to take the bike on dirt eventually
05-21-2016, 09:02 PM | #8 |
Woodlandsprite, if you get the CSC bash plate I'd recommend two mods before you mount it. The plate has a really tight fit on the upper right and along the right side. I'd cut some of that off:
You could even be more aggressive than my marks. The second suggestion is on the left side I'd cut a hole to give access to the plug you need to remove in order to find TDC so you can set the valve lash. I discovered this after this photo was taken and I have yet to make this mod because my mill is dedicated to another project. As for taking the plate off to change oil...I did not. The strainers will drop oil onto the plate and you will have a bit of mess but IMHO that's not a big deal. I installed a quick drain valve so dropping the oil is fairly painless and clean. If you go this route make sure you get the 16mm version. |
05-22-2016, 03:11 AM | #9 | |
I never use the inspection hole on the stator cover any more. If you use the inspection ports on the rocker cover, you don't need to modify the CSC skid plate on the left side.
05-22-2016, 10:23 AM | #10 |
http://www.cscmotorcycles.com/QUICK-...p/csc-3004.htm I would cough up the $60 and make it clean and simple for the duration. By the way, buy the new cool skid plate while your at it.
05-21-2016, 05:53 PM | #11 |
If you want to achieve clean oil changes, put the bike on the side stand, and don't get the CSC skid pate.
05-21-2016, 06:27 PM | #12 |
Rx3 'ers, what is going on with the plate. Could a large access hole be drilled to accommodate a socket and also to allow the flow of oil through this hole . Thinking of , say a
1 1/4" to 1 1/2 " hole saw. I can't see what's going on when its mounted unless there is a frame causing issue, so just an idea.
05-21-2016, 06:29 PM | #13 |
Oh, OK I see the drain plug is not straight down but looking off to the side, got ya.
05-21-2016, 08:29 PM | #14 | |
05-21-2016, 08:33 PM | #15 | |
also Spud is correct that the oil screen plugs and oil filter cap will dump right into your skid plate |
