03-19-2016, 09:39 AM | #1 |
Anyone know what would cause this?
My Blinkers don't flash, they just stay solid color, also my horn doesn't work.
Would Anyone have an idea what would cause this, I am wiring up my bike to make it road legal. Thank you |
03-19-2016, 10:38 AM | #2 |
What vehicle/motorcycle are we talking about? Did you change any light bulbs lately (maybe changed some to LEDs?)?
If it's all original lights/flasher then: I would start by checking the "Flasher" and any/all wires leading to your switch/buttons, the lights/horn, fuses, and the ground wires. Usually a "solid/not flashing blinker" is due to a burnt out bulb, not enough electric draw to cause the "Flasher" to work, or an old and tired "Flasher" that doesn't work anymore (most only have a working life of 60 to 140 hours). If it is your "Flasher" might I suggest looking into the Tridon brand (made in Australia), I always use them when I needed a new Flasher, I'm still using the one I bought 14 or 15 years ago for my Eagle Talon and it only cost $10 or $12 last time I bought one. If you changed to LED Turn Signals, then you will need to either wire in some resistors or find a LED Flasher that is compatible with your vehicle... Both I'm not the best at with helping, I always got my Dad or the Internet to help me with the LED Turn Signals/Resistors wired.
03-19-2016, 01:19 PM | #3 | |
Flasher? Resister?
I dono, but maybe ill buy a flasher and install it on the blinker wires? do I need 4 flashers or just two? One on the Light Blue wire and One on the Orange wire? Any tips on fixing my situation would be great. Thanks |
03-19-2016, 04:53 PM | #4 | |
Just one Flasher should work for the entire system, but it depends on what bulbs and watts/amps drawn on them to what Flasher you will need. With the horn, you will need to wire in a fuse and relay also to get it to work properly, might need to check the ground(s) if it already has a relay/fuse wired in
03-19-2016, 10:02 PM | #5 | |
Hi, Thanks for helping me. Ok ill find the ad where I got the Blinkers. Not to sure what watts they are.. So I need one flasher and a fuse and a relay, what amp of fuse and where would I buy these things... Any tips on where and how to install them etc? |
03-19-2016, 10:44 PM | #6 | |
http://www.chinariders.net/showthread.php?t=15137 #6 is a splitted diagram The FULL format should be somthing like http://pan.baidu.com/s/1pJZJQGz --- http://item.taobao.com/item.htm?id=36546726632 Flasher (闪光器) is the T plug
03-20-2016, 09:54 AM | #7 | |
Ok I found the ebay purchase history. They are LED Lights. 4x Black Front Rear Motorcycle LED Turn Signal Light 39mm Fork Clamp http://www.ebay.ca/itm/4X-Motorcycle...RWXfcB&vxp=mtr So what items do I need to fix this issue? |
03-19-2016, 06:08 PM | #8 | |
Sorry to say this.... Really mate.. If yer didn't know you needed a flasher unit I don't think you should be playing around with the wireing at all... And if you want to learn.... have someone beside you to learn from... ..
03-19-2016, 10:01 PM | #9 |
Love doing it
[QUOTE=pete;208105]Sorry to say this....
Really mate.. If yer didn't know you needed a flasher unit I don't think you should be playing around with the wireing at all... And if you want to learn.... have someone beside you to learn from... Yes I agree, but right now Spud is taking me step by step in the process of learning, I do not have anyone to show me, and I wish I did. This is a good learning fase for me and enjoying every minute, I have a lot of patients trust me. With 3 kids in the house I'm good to go This will teach me a lot, I enjoy doing it. |
03-19-2016, 02:18 PM | #10 |
Just one. The blue and orange wires should come from either side of the ts switch.
03-20-2016, 10:49 AM | #11 |
LED & Flasher http://www.chinariders.net/showthread.php?t=16090
