Old 02-07-2016, 08:03 PM   #1
Dualsport Chic   Dualsport Chic is offline
Dualsport Chic's Avatar
Risers?
Has anyone installed risers on their RX3s? I'm a shorty - short-ish legs (29" inseam) and shorter torso (5'3" height) and usually need risers on my bikes (Triumph Tiger 800 & BMW F650gs).
Looking to see if anyone has needed risers and what options they've found that work for them.
Thanks all!
Old 02-07-2016, 08:19 PM   #2
Jay In Milpitas's Avatar
Welcome Dualsport.
I'm sure you will receive answers from others who have put risers on, I haven't needed them.
However the Cyclone is a pretty well laid out bike that a lot of riders of varying heights are finding comfortable. You might wish to lower yours, either by adjusting the rear spring preload or going serious and adding the optional 1" lowering link. CSC isn't showing any affiliates in CT, but I think we have someone here that is in your area.
If you've run a Tiger 800 and BMW F bike, you will be happily surprised with the RX3 and how it handles & performs. Light, too.
Old 02-07-2016, 08:27 PM   #3
Originally Posted by Jay In Milpitas View Post
Welcome Dualsport.
You might wish to lower yours, either by adjusting the rear spring preload or going serious and adding the optional 1" lowering link. CSC isn't showing any affiliates in CT, but I think we have someone here that is in your area..
Hi Jay and thank you for the welcome! Not a fan of lowering links - alters geometry of the bike too much and I will use my RX3 for dirt road touring so need as much ground clearance as possible. Ordered the narrow seat and also have Daytona boots which should fit the bill to get the balls of my feet on the ground.
However, after two back surgeries, I'm going to need to make sure my back is not at too much of a forward angle - need as standard of a seating position as possible as I am planning 300 mile days on the dirt with this bike so must be comfortable. Hoping I can get some suggestions on riser choices from anyone who has tried them.
Old 02-07-2016, 08:31 PM   #4
DanKearney   DanKearney is offline
I installed a set of 1" risers on my RX3 to make it more comfortable to ride in standing postion.
Works well for me. I am 5' 7".
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 02-07-2016, 08:37 PM   #5
Dan - what type of risers did you go it - straight up or rotating (like Rox)?
Old 02-07-2016, 08:50 PM   #6
rjmorel   rjmorel is offline
rjmorel's Avatar
DSChic, I installed 7/8" risers on my RX3 that are just a simple round bushing that goes under the handle bar clamps. I needed to get longer bolts to replace the original ones. I think 1" is about as high as you can go before the cables get to tight. I'm 5'6" 28" inseam and I have the lowering link and lowered the forks down also. I'm always on the short side of bikes it seems. Heres a pic of how I did mine, rj
Live Zong, and Prosper
Old 02-07-2016, 09:21 PM   #7
Wondering if the cables will be long enough for a pair of 1" ROX risers so I can pull the bars back towards me more. Your thoughts?
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
Old 02-07-2016, 11:03 PM   #8
rjmorel's Avatar
I would guess that they would be long enough but you may need to get under the gas tank and free up the cables to get more slack in them or reroute them so they don't bind when turning bars fully to one side or the other, rj.
Old 02-08-2016, 04:21 PM   #9
jbfla   jbfla is offline
I think the 1" Rox risers will be fine, and I like their adjustability.
The Tusk risers are 30mm = 1 3/16", and they don't go exactly straight up.
They lean slightly back at the same rake angle as the forks.
jb
2014 XT 250........
Old 02-07-2016, 11:01 PM   #10
Just a generic set of billet aluminum risers. No adjustability. The cables were long enough so there was no problem with that amount of change. I'm not sure if the cables are long enough to also move the bars forward or not. It's late and it's cold and I'm too lazy to go out to the garage to look at the bike. . .
Cheers,
Dan K.
Old 02-08-2016, 06:55 AM   #11
I believe several people have installed the 30mm, Tusk handlebar risers without any problems. You need to get the 1-1/8 inch, big bar adapters.
https://www.rockymountainatvmc.com/p...ndlebar+risers
Old 02-08-2016, 10:19 AM   #12
Huck369   Huck369 is offline
Huck369's Avatar
I too have the Tusk Risers on mine, no issues with the cables
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 02-08-2016, 11:09 AM   #13
keithmaine   keithmaine is offline
keithmaine's Avatar
I also used the same risers as Spud
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp,
Old 02-08-2016, 12:35 PM   #14
rtking   rtking is offline
That makes 3 of us (so far) with the Tusk risers - no issues, enough slack in cables, so no movement / re-routing of cables required.
Old 02-08-2016, 12:54 PM   #15
But how about moving back vs. straight up?
Really need to understand available cable clearance as Rox Risers are over an inch - the tusks are of no use to me as they don't bring the bars back towards the rider, only up.
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
