Old 11-29-2015, 08:15 PM   #1
justinope   justinope is offline
19" front wheel or stick with the 18?
Hey again! I've noticed a lot of people on here have stuck with the 18" front wheel from the bike instead of going up to a 19". how have you guys found that to work on and off road? I was thinking it'd be nice for tire choices really mainly but I've noticed on the forums some people have found great functioning tires in the 18" size. Anyone tried a 18 and a 19 front and have an opinion maybe? I think this is my actual last concern before buying tomorrow.
I just figure they use 17/19 on the GS's for a reason and other bikes instead of 17/18 but maybe not
Old 11-29-2015, 10:08 PM   #2
I'm happy with the 18-inch front wheel. If I make any change, I will switch to a 21-inch front wheel, but I don't have any current plans to do so.
Old 09-11-2016, 12:25 AM   #3
StevieUT   StevieUT is offline
StevieUT's Avatar
Hey Spud, I dented my stock rear rim a little and I'm planning on taking the opportunity to lace up a a new warp 9 rim. However I'm thinking about going with an 18x2.5 rear and a lower sprocket. With a 18" rear would you recommend going up to a 21" front? I'm hoping that would make the bike more trail friendly. Any drawbacks to this config in your opinion?
Old 09-11-2016, 05:02 AM   #4
willy dog   willy dog is offline
willy dog's Avatar
the 17inc. rear can bottom out and scrape the inside of the fender and air box would be careful adding to rear tire
Peace and Zong Life
Old 09-11-2016, 07:17 AM   #5
surfndirt   surfndirt is offline
surfndirt's Avatar
Exactly, and this is a 18" with a K270, plastic shield guarding airbox has completely eroded away, and the screw holding the airbox sides together is no longer existing since its work down through the thread hole, mudflap hook is no longer there either. Added JB plastiweld as a temporary fix on some of these things
Airbox is about to get broken next, not to mention the caliper bolt dents in my muffler. Yes I ride it like a rally bike...but hey...I can't say it hasn't gotten through anything I've thrown at it. Currently in contact with CSC if they can work with me on somehow amending this issue.
13t sprocket and stock front size is fine for offroad, sand just takes some getting used to with this bike, as well as knowing it's limits with ruts.
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.)
'82 Suzuki SP250 (11k Miles)
'85 Honda Rebel 250 (Sold April 2016)
Old 09-11-2016, 12:56 PM   #6
StevieUT's Avatar
Yeah, I'd say that's a drawback. I'll stick with the 17" rear but with a warp9 rim. I really want to install a rim lock and there's nada for the stock rear rim. I do think I will go at least with 19" in the front, which should help with the silt I run into. Also, I'm not crazy about the lack of availability of heavy duty tubes for the 18" front.
Thanks for the replies!
Old 09-11-2016, 12:59 PM   #7
Thumbs Up
Wow surf, you were not intended to get such use and abuse from a $3800 motorcycle. Cease and desist immediately and go purchase a $15k bmw.
Old 09-11-2016, 05:50 PM   #8
GSC   GSC is offline
Especially with the ' lowering link ' installed.
I must add that Ryan warned me first ! I went for it anyway, and yes a few hard knocks and the Kenda big blocks scrape the air box connectors.
Old 11-29-2015, 11:15 PM   #9
detours   detours is offline
detours's Avatar
I have the 19" front wheel and love it. CSC sent the 18" with the bike, but I never installed it so I can't compare. The 19 feels very planted on road and dirt, so I have no reason to switch to the 18.
A larger wheel handles rocks and bumps better in general, but spudrider has done more technical trails than me (and most) with his 18" wheel. You might consider sticking with the 18 for now and rebuilding it with a 19" alloy rim later.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 11-29-2015, 11:25 PM   #10
DanKearney   DanKearney is offline
I swapped the 18" for a 19" and put the Kenda big block tires on the bike. The rubber is so different from the stock tires that I really can't compare the two. Conventional wisdom says bigger front wheel = better trail handling. I'm no expert.
I rode the bike, fully loaded from Denver area to Taos, NM and then a bunch of Forest Service road riding after I arrived. The Kenda's were much better on the packed dirt roads than the standard tires. I'd say the Kendas are just as good on tarmac as I remember the comparable Continental TKC-80's were (on my BMW F650GS).
With the 19" front wheel there are more tire choices in the 50/50 and 70/30 on/off road range that I like to ride on.
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 11-29-2015, 11:44 PM   #11
hmm I wonder if the 18" wheel would be resellable at all to someone looking for one somewhere either for this bike or others. if I could get back like $100 from it, it'd be a no brainer choice for me
Old 11-30-2015, 07:15 AM   #12
Huck369   Huck369 is offline
Huck369's Avatar
The 18" does fine, the difference is minimal between the 18 and the 19", the only real difference is choice of tires, but I have found plenty of 18" tires that I like.
I don't think an average rider will be able to tell a difference in the 2....but a 21" would be a big enough difference that it'd be very noticeable....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 11-30-2015, 08:55 AM   #13
I plan to swap the original 18" front wheel and OEM tire back on when I am doing my commuting runs and put the 19" knobbie back on when trail riding is in the offing.
Cheers,
Dan K.
Old 12-29-2015, 05:08 PM   #14
Parker   Parker is offline
19-inch tire
I am planning on tackling a BDR next spring and thought I'd try a 19-inch tire on the front of the RX-3 and a 13t sprocket. I figure this will give me a little more on the bottom end for the dirt without affecting handling on the paved portions of the route. Any thoughts?
Old 12-29-2015, 06:11 PM   #15
I don't have a motorcycle lift, so I need to lie down on the driveway to check the flywheel inspection port for TDC. It's much easier for me to sit, and check the cam inspection ports for the timing marks.
