Old 09-03-2015, 10:27 AM   #1
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
Recommended toolset for travel?
Hi folks.
Have in mind to do some mixed on/off-road traveling (let's say, 70/30%) through places similar to those beautifully depicted by SpudRider: open roads, lakes, mountains (but 5,000 miles South of him ).
Based on your personal experiences ¿What is the mínimum recommended toolset and accesories for these kind of trips?
Thanks.
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 09-03-2015, 10:39 AM   #2
Are you buying, or do you own a Zongshen RX3?
Firstly, you need to carry tire repair equipment. Does the RX3 sold in Argentina have a 15-inch rear wheel?
Old 09-04-2015, 09:09 AM   #3
Still haven't buyed the RX3 : hope to do that in a couple of weeks.
The Argentina's model has 90/90-18 (front), 130/90-15 (rear).
Thanks EcoMouse and LouisAngel!
______________
Old 09-30-2015, 05:03 PM   #4
peperino   peperino is offline
Cmon man!
Correction: 100/90/18 front. The webpage has wrong information
Old 10-01-2015, 08:59 AM   #5
Originally Posted by peperino View Post
Cmon man!
I'm really decided to afford this motorcycle!
However, currently there are "wind of changes" at my company (a.k.a. headcount reduction) and related business at my area, so I'm waiting for a more clearer horizon to afford this kind of investment.
Have faith to solve this situation soon.
Thank you for your support
______________
Old 10-01-2015, 12:56 PM   #6
rjmorel   rjmorel is offline
rjmorel's Avatar
Juan, hope all works out for you at work. Sometimes waiting a few weeks or months before a major purchase can be very enlightening. Getting in a hurry has always cost me in a bad way. Patience with faith that a rainbow is waiting at the end of a storm has always worked for me. Good luck, rj
Live Zong, and Prosper
Old 09-03-2015, 03:15 PM   #7
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
The best way to determine with tools you'll personally need is to do a through maintenance on your bike. Because there is no sense in taking tools along that are outside of your trail maintenance skill set.
So, the best way is in the comfort of your own garage, and a set of your tools. Start by removing the wheels, as if you had a flat tire. Then start by doing a tear down to get access to your valve adjustment covers. This gets you most of the way torn down as if you had to do any other kind of maintenance.
Now carefully take stock of the exact tools you used to remove everything. And pack those tools up only.
Some good odds and ends things to have with you are:
• Short length of spare electrical wire + some common connectors and electrical tape
• Zip Ties & a short section of bailing wire
• Tire Irons/Spoons
• Chain Breaker Tool
Old 09-03-2015, 03:32 PM   #8
Louis Angel   Louis Angel is offline
Louis Angel's Avatar
Yeah. What Eco Mouse said.
I also bring along a spare spark plug, a few spare bulbs (safety & legal reasons) and a spark plug socket. Once thing I do different is instead
of a chain break tool, I keep a new metal file. once two pins on a chain are filed down, they come part real easy. Does not take long and not as much space/weight to have to pack around. Plus a file has other uses. However! IF you have the room for a real chain breaker tool, by all menas carry one!
Also be sure to bring a quart (or two) of proper oil with you.
I run tubeless tires, so I have a Slime tire repair kit and a can of
fix-o-flat. Nasty stuff to use, but can get you by till a replacememt
tire can be installed at a tire shop / back at home.
" If it ain't broke, I can probably still fix it!" ---- Tim Allen
Old 09-04-2015, 12:10 PM   #9
I suspected as much, but I wanted to know for sure.
I suggest you carry the following tire changing equipment.
3 portable tire irons
Inner tube repair kit
Hand air pump
Electric air pump, or CO2 cartridges
Small bottle of talcum powder
Small bottle of hand soap
In the United State, I suggest RX3 owners carry a spare inner tube, size 100/100-18. If you slash an inner tube, or rip the valve core from the tube, you won't be able to repair the inner tube. The size 100/100-18 tube will fit both wheels of the CSC motorcycle in an emergency.
Since your bike in Argentina has a 15-inch rear wheel, I suggest you might want to carry a spare inner tube for both tires if you are traveling on an extended trip.
Old 09-04-2015, 01:21 PM   #10
Thanks
Very interesting; I think it will be of value to other bikers too.
folks!
______________
Old 09-27-2015, 10:09 PM   #11
detours   detours is offline
detours's Avatar
I discovered that my bit driver set fits under the passenger seat under the stock tool kit. It's a nice addition to my tool kit.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 09-27-2015, 10:32 PM   #12
That's great. Do you having any trouble getting the pillion saddle to latch into place?
Old 09-27-2015, 11:35 PM   #13
detours's Avatar
It's a little tight, but a little pressure right over the latch and it catches. Nice and snug.
Red 5 standing by!
2014 Ural Patrol
Old 09-28-2015, 12:09 AM   #14
paisleyrider   paisleyrider is offline
Another rear seat toolset ooption
My Cruz tools 3/8 inch Powerdrive t-handle fits nicely under the rear seat for easy access to many of the bits and sockets I'll need for work on the bike. It's missing 18 and 19 mm sockets which are needed for wheel removal. I stuck a neodymium magnet to the side of it that I can stick to the tip in case I lose a piece of metal in a hard-to-reach part of the bike.
It has to be positioned in this exact placement or else it gets in the way when I reinstall the seat; I may rig up a retaining piece to dampen vibrations and make it easier to get it in just the right configuration.
http://www.amazon.com/CruzTOOLS-TSDS.../dp/B000GTYPQA
Old 09-28-2015, 12:56 AM   #15
detours's Avatar
Very nice!
Red 5 standing by!
2014 Ural Patrol
