Old 05-28-2015, 12:45 PM   #1
katflap   katflap is offline
katflap's Avatar
Working With Diagnostic Data Cable & Software
UPDATE (June 2020)
The PCHUD software is now completely obsolete & has been superseded by the fully functional HUD ECU Hacker software.
Thanks goes to Raptorix (Elmüsoft) for creating & developing this new software.
Detailed description & download for the HUD ECU Hacker can be found here
https://netcult.ch/elmue/HUD%20ECU%20Hacker/
LINK UPDATE (2018)
See post 164 & 165 for PCHUD download
This is an all in one download that includes
PCHUD with instructions
"Clear fault codes" software with instructions
A guide to making your own data connection using a vag com cable
and other info
Requirements
1/
Data Cable
Taobao link
http://item.taobao.com/item.htm?id=39520023502
so far the only one known to work
2/
PC or laptop running Win7 (32bit), Tested
May work with other O.S. NOT 64bit
The diagnostic software comes indirectly with the cable. If this is not the case, below is a link to the software I received (PCHUD)
https://mega.co.nz/#!skACACIT!Kv8o9g...KYCK-q08TiBUs8
The software is in Chinese, below is a link, in the download are files and instructions translated in to English. I will go in to more detail of these files further on in this post
https://mega.co.nz/#!wwgkDAwR!QzhC2n...cYKva96H8_KMuY
Installing USB drivers and running software
The translated instructions included in my link should do the trick, so i will only write an overview here.
The setup.exe for the USB drivers can be found in the "USB数据线驱动程序及安装指南" folder
Run the setup without the cable connected to your laptop
No installation is required for the PCHUD software
The folder "德尔福电脑检测软件(PCHud_Chinese)" needs to be renamed to PCHUD, then just place the folder in the root of the harddrive .
I used D:\ as described in the instructions, but probably would work else where if you edit the pchud.ini
Check the pchud.ini anyway to make sure the directory entries are correct.
Launch and experiment with the software without anything connected (run hud.exe)
The important data to load is the .par file, this holds all the parameter data. The VARI54CN.PAR file
is the one that you can see being used in the Delphi Scan Tool Manual (included in my download).
Unfortunately the VARI54CN.PAR is in chinese but i have done my best at translating it (3.par)
The .hud files are user configuration files for the gauges. You are able to create new ones from within the program.
so to get you started use -
3.hud with 3.par
or
1.hud with 1.par ( slightly different translation of VARI54CN.PAR)
Translating or editing of .par files yourself i will cover in a later post, but i have included a hex/text editor that will be required in my download)
The Chinese TR125 (QJ125GY-16A) uses the Delphi MT05 , i have included the EFI section of the manual in my download.
The images show them using the MT05common.PAR as their parameter file.
For this use 2.hud with 2.par (slight variation on the MT05common.PAR)
connecting up
with ignition off plug the cable into the bike, USB to laptop and run PCHUD.
make sure comports are configured, bike kill switch is to "run" turn on ignition.
"com time out error " should go after a short while, if not start engine and all should be good
apologies for the length of, post now completed
Old 05-28-2015, 02:00 PM   #2
Thanks for posting this excellent thread, Kat.
My fifth order with Taobao is ready for shipment, but I am delaying it, because I am adding this cable to my order.
Old 05-28-2015, 02:28 PM   #3
katflap's Avatar
Thanks Spud,
I'm still adding more stuff to my first post over the next few hours, fitting it in around other things i have to do, will mark it as completed when done
I also added the cable to an existing order, the agent received the cable very quickly, so in the end it was waiting on components to arrive for my existing order that held up the shipment.
I had 2 orders shipped at nearly the same time, this one got through, the other got caught in customs. so i will have to pay duty on that one
Old 05-28-2015, 03:50 PM   #4
katflap's Avatar
Translating,Editing .par files
Open the .par file with M.S. Word , select other encoding Chinese simplified(EUC).
From here you can translate by copying in to google translate.
For editing ( software provided in 1st post download)
Open .par file , in the right hand column you will see sections of code strings.
select view, character set, International, Chinese simplified so you can match the chinese characters .
Note the start point , change back to ACSll and edit
TIP - 00 in the left hex column = nothing.
** this all takes forever to do**
If your editing one of my .par files , they are already in English.
Old 05-28-2015, 04:21 PM   #5
katflap's Avatar
Simulating A Fault
I disconnected the O2 sensor to see what would happen.
as you can see in the pic it displayed that the fault light was on and recorded at fault number of 49.
This means from the table a P0031 fault, Oxygen sensor Heater high voltage.
Not quite what I was expecting but at least it was the right component
Old 05-28-2015, 04:52 PM   #6
rjmorel   rjmorel is offline
rjmorel's Avatar
As a total nube what does this do for me and the bike? Is it for going in and changing parameters to make it a BMW or KTM? ) Need a 101 wannabe geek coarse for changing any of it. How and why? The rest of the mechanical things I can screw up all by myself. rj
Old 09-13-2018, 06:18 PM   #7
engtro   engtro is offline
Hello dear Katflap,
I tried download link for first post but the link was offline. Could you share software for edit *.par files?
Old 05-28-2015, 06:23 PM   #8
You are certainly going to get more data from a computer than you will from an OBD2 scanner.
Old 05-08-2016, 02:13 PM   #9
dpl096   dpl096 is offline
dpl096's Avatar
BT Diagnostics
Kat;
Would something like this work with an adapter?
http://www.ebay.com/itm/BAFX-Bluetoo...699259&vxp=mtr
― Thomas Jefferson
Old 05-08-2016, 02:33 PM   #10
Originally Posted by dpl096 View Post
Kat;
I doubt it will work. The Delphi MT05 ECU does not appear to be OBD2 compliant, or it would work with any OBD2 scanner, which it does not.
As far as I know, the Delphi MT05 controller is proven to communicate only with PCHUD software running on a Microsoft Windows computer, and these two, compatible scan tools.
1. Delphi Scan Tool KF90121
2. ED100 Motorcycle Scan Tool
PCHUD software is easily the least expensive, and most powerful tool for diagnosing the health of the Delphi MT05 ECU.
Old 05-08-2016, 03:45 PM   #11
dpl096's Avatar
I still think it's a cool piece of hardware and software. Now I'm wondering about a windows tablet . Use it with the proper software and a cable .... there's a couple of windows based tablets on ebay for decent prices.
― Thomas Jefferson
Old 05-10-2016, 09:06 AM   #12
katflap's Avatar
Kat;
In addition to what spud has already said,
there have been a few people try a bluetooth connection but I believe without success. Also I have tried the Torque app with an android emulator with know success but admittedly it could be a connection issue between the com port and the emulator.
Old 05-29-2015, 01:24 AM   #13
What???
Don't apologize for an awesome contribution like that! You're the man.
Old 05-29-2015, 01:30 AM   #14
He's not the Grand Poobah for nothing.
Old 05-29-2015, 05:46 AM   #15
humanbeing's Avatar
VW cable (twenty-odd yuan) mod :http://www.chyangwa.net/forum.php?mo...uthorid=652893
