Old 05-16-2015, 01:35 PM   #1
Jaycar Speedo Corrector
One of our newest forum members, JTHSpace, discovered a very nice, small, reasonably priced, speedometer corrector manufactured in Australia. The JayCar Speedo Corrector is 2.5" x 1.8" x 1" in dimensions, and has a shipping weight of only 3.5 ounces. Here is a link to the product shown at the vendor's website in the United States.
http://www.jaycar.us/productView.asp?ID=AA0376
Here is a link to the product's user manual.
http://www.jaycar.co.uk/products_upl...l%20AA0376.pdf
If you purchase ten or more units, the price is only $23.00 USD, plus shipping. Is anyone in the United States interested in a group purchase of this speedometer corrector? If so, I am willing to handle the details.
Old 05-16-2015, 01:46 PM   #2
This speedometer corrector was originally available as a kit.
http://www.autospeed.com/cms/article.html?&A=108415
http://www.4wdaction.com.au/forum/vi...?f=10&t=141776
However, you can now buy the completed unit, which is smaller, and you don't need to do any soldering.
Old 05-16-2015, 02:20 PM   #3
The Jaycar Speedo Corrector is wired into the RX3 the same way as the SpeedoDRD unit from 12oClockLabs.
The RX3 employs a sending unit on the front wheel which uses has three wires. One wire contains 12V DC, which powers the sending unit. The other wire is a ground wire. The third wire transmits pulses from the sending unit to the Siemen's speedometer.
We would tap into the three wires on the opposite side of the connector, at the wires that lead to the speedometer.
One wire feeds 12V DC to the speedo corrector, and one wire feeds the ground connection. One wire feeds input from the RX3 sending unit to the Jaycar unit. One wire feeds the corrected signal from the Jaycar unit to the speedometer.
The Jaycar unit has convenient holes in the housing, so we could attach the unit under the dashboard with zip ties.
Old 05-16-2015, 02:26 PM   #4
Tapping into the wires on the dashboard side of the connector will allow us to easily and quickly replace the stock sending unit if it becomes damaged.
Setting the S1 and S2 potentiometers allows you to fine tune the Jaycar speedometer corrector for excellent accuracy, allowing you to change tires, wheel sizes, et cetera, and still obtain a very accurate speedometer reading.
Old 05-16-2015, 04:21 PM   #5
G19Tony   G19Tony is offline
G19Tony's Avatar
I was interested, up until it said not to get the module wet. I'll pass on this one. Thanks for sharing it.
Honda CB300R ABS
Old 05-16-2015, 05:19 PM   #6
woodlandsprite   woodlandsprite is offline
woodlandsprite's Avatar
*sigh* Tony, your post made me heave a big sigh - it was looking so promising until that part about getting wet! LOL
Old 05-16-2015, 05:29 PM   #7
Veteran   Veteran is offline
Veteran's Avatar
Spud,
I'd be interested in 3 of them. If you decide to do a group buy, let me know what your Paypal is or how else you'd prefer payment.
EC
Old 05-16-2015, 06:11 PM   #8
Originally Posted by Veteran View Post
Spud,
EC
Duly noted, Veteran. The next cheapest alternative is the SpeedoDRD from 12oClockLabs for $70, and I think this unit is much better protected, and much easier to calibrate.
Old 05-16-2015, 11:14 PM   #9
Veteran's Avatar
Speedo correction
Maybe a sailor should pay more attention to detail; I didn't see where it said not to get it wet. While I appreciate the vote of confidence in my ability to waterproof this thing; now that I know it's a water-sensitive item, I think I'm going to have to retract my request to be put on the list for them. I can live with thinking I'm faster than I am if it's not fairly bulletproof out of the box.
Sorry Spud, and sorry for the double post; I haven't a clue how that happened.
Old 05-16-2015, 06:11 PM   #10
oldqwerty   oldqwerty is offline
Spud,
EC
No doubt a sailor in today's Navy knows how to keep electronics dry. Please share when you have a chance to set yours up. I plan an aluminum box cut from a solid chunk, with cooling fins if necessary, and a waterproof bulkhead plug for wires. Overkill? Of course, but more than enough means never having to say spizz-zzzit.
SpudRider, what do you figure delivered in the U. S. of A. is going to cost?
"Thou shall not Zong" is not a commandment.
Old 05-16-2015, 06:36 PM   #11
I'm sure both you, and Veteran can hermetically seal this unit.
I sent an email to the vendor, but I don't expect a reply until Monday. The shipping weight for each unit is only 3.5 ounces, so I think the individual shipping cost on ten, or more units should be pretty reasonable. Then, of course, one would need to add the cost of shipping each unit to the individual buyers. However, the SpeedoDRD unit costs $70, and I'm sure the final, delivered cost of this item will be much less than that. I would guess the final, delivered cost of this unit would be $35, or less.
Old 05-16-2015, 07:25 PM   #12
I'm in at 35 delivered.
Given enough of the right kind of sealant, anything can be waterproofed. Watch these Jeeps hit Sippy Hole and imagine what it takes to waterproof a Jeep ignition.
Old 05-17-2015, 02:07 PM   #13
I'm going to use that line at work.
Old 05-16-2015, 06:08 PM   #14
I don't think it would be that hard to waterproof the case. Also, one could mount this unit under the pillion saddle, and extend the wiring to the dashboard. However, I do appreciate your concerns.
Old 05-17-2015, 01:53 PM   #15
This would be my approach: http://en.wikipedia.org/wiki/Self-amalgamating_tape
