11-16-2014, 09:16 AM | #1 |
tao tao 125, electrical issues
I bought my kids a tao tao 125 for Christmas last year. Besides replacing the starter, it's been a good little atv. Yesterday I went to start it after leaving it on my trickle charger for a few hours. When I turn the key, the neutral light comes on, but the lights don't come on and the solenoid doesn't click. I checked for loose wiring, but found nothing. On another note, I can't seem to locate the fob either.
Any help would be appreciated. |
11-16-2014, 10:39 AM | #2 |
Do your lights run off battery power or off the stator?
I thought most lights run off stator power when the engine is running only |
11-16-2014, 02:51 PM | #3 |
I honestly don't know.
11-16-2014, 03:01 PM | #4 |
My lights only come on when the engine is running.
11-16-2014, 03:33 PM | #5 |
I can't remember if they come on only when it's running. Either way, I can't get it to turn over.
11-16-2014, 08:55 PM | #6 |
Safety switch ?
11-16-2014, 11:41 PM | #7 |
My guess is that the battery is done. Can you connect another battery with booster cables?
11-17-2014, 02:57 PM | #8 |
I'll check it today. I'll jump it with my truck and see what it does.
11-18-2014, 10:49 AM | #9 |
Make sure the truck is not running.
11-19-2014, 07:10 PM | #10 |
jumping battery
yes do not try to jump start with a major truck or car battery... the battery in the atv is usually 50 - 90 amp ( unless a larger 150 & up... then about 200 amp ) this could blow the battery up... I have had customers do this .. and show me the battery... the top is blown off .. I always say to use a riding lawnmower or other atv.. to do this.. about the same size battery for safety.. most of the time starting problems are the battery... rather than getting into wiring an d other open heart surgery to find this problem.. start off small.. battery dead or ?? just because it says 12-13 volts does not mean it has AMPS to turn it over.. you can always jump the solenoid and then jump the starter before you start to remove stuff...
