01-26-2017, 09:03 PM | #1 |
New Hawk owner in Pearland, Texas. Glasspack exhaust etc...
A fun new toy with upgrades that don't break the bank. Top speed 66mph.
01-26-2017, 09:08 PM | #2 |
welcome to the forum. did you tear out the cat in the exhaust?
01-26-2017, 09:23 PM | #3 |
Good question. Where is the cat located?
01-26-2017, 09:30 PM | #4 |
bulge in pipe under the heat shield near the motor.
01-26-2017, 10:10 PM | #5 |
Thankyou. I have a new project to remove it. Probably cut it out with sawsall or cutoff wheel and jb weld pipe back togethether.
01-27-2017, 07:38 AM | #6 |
Once you gut the cat you could always bring it to a muffler shop and have them weld it up if you don't have access to a welder. I'm not sure JB weld will hold up with the vibration from the motor. But at the same time I would be curious to see how weld the JB weld would hold up.
01-29-2017, 07:59 PM | #7 |
Catgut complete and removed the exhaust clamp. I bought a $100, 90 amp welder from harbor freight and did the welds myself. The welds are'nt pretty but fuctional with no leaks.
01-29-2017, 08:38 PM | #8 |
Which pod filter you running for the carb and engine breather. I may have melted my airbox today...
01-30-2017, 11:32 AM | #9 | |
01-30-2017, 12:01 PM | #10 |
Uni brand air filter 42mm and crankcase vent 1/2" pipe fitting. I removed stock airbox, cat and and stock muffler and slipped on a 23" glasspack.
01-30-2017, 02:09 PM | #11 |
did you replace the air box with some type of plastic guard so that you're not slinging mud back up in there? That's the primary reason I left mine.
01-30-2017, 02:12 PM | #12 |
what welder did you get and how did it do for you? I'm wanting to get one. a long time ago I had a cheap stick welder which did not work out so well due to limited power. it didn't seem to want to properly melt the two ends of metal for a good bond. (this coming from a VERY rank amateur!)
01-30-2017, 07:44 PM | #13 |
To prevent debri from rear wheel I fabricated sheet metal guard. See pic:
I purchased the flux core wire feed welder. Works well for the price and my welding inexperience. |
01-27-2017, 09:06 AM | #14 |
Good idea for muffler shop. Thanks
01-27-2017, 09:12 PM | #15 |
jb weld will melt at the high temp of exhaust.
