Old 07-10-2019, 12:24 AM   #1
1qkbull   1qkbull is offline
Battery light flashing..
Hi everyone, this is my first post and I'm hoping someone can help me out with these problems I've been having with my Bull 200
First off I bought it brand new in December 2018. When the dealer I bought it from delivered it to my house, I noticed the battery light on the instrument cluster was flashing. I asked the guy why is this flashing? He said he thinks it will go away.. ok.. it never went away...its still on 7 months later.. also the battery was dying everyday that I used it.. I put a volt meter on it and it shows 14.5 volts while idling no load, as soon as I turn in the lights it dropped down to 13.5 then the high beams 13.2 then use the winch and its down to 12-12.5
So my question is does anyone know what the flashing battery light means?. It also flashes with the key on and engine not running. I replaced the battery and same problem, also replaced the rectifier/regulator which was worse.. did not charge at all so I put the original regulator back on, at least it charges with no load.
Thanks in advance.
Old 07-10-2019, 10:17 AM   #2
Welcome!
Was the replacement reg/rec identical to the original?
Old 07-10-2019, 11:51 PM   #3
Welcome!
No it was missing the fins on the side.. but otherwise looked the same. I'm going to return it..
Old 07-10-2019, 10:31 AM   #4
duck9191   duck9191 is offline
Mean the voltage is too high or too low. Where are you measuring voltage at? May want to check at the cluster too.
There isn't a stator that will keep up with a winch, so the voltage will sag during use. It's a common issue with plowing snow that you can kill your battery with extended winch usage. The other voltages look fine, anything over 12.9v will "charge" but not efficiently or fast, mid 14's are ideal.
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 07-10-2019, 11:26 AM   #5
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Sounds like your electrical system is operating perfectly fine. I suspect the issues is that the warning light is not calibrated properly. There may be an adjustment on the back of the cluster if it really bothers you. It shouldn't light up unless the voltage is below 12.5v.
Electrician & Electronics Tech
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 07-10-2019, 11:58 PM   #6
Measuring at the battery,.. the voltage is suppose to stay steady when you put a load on it,.
But I'm beginning to believe you're right it's just too much load for the stator to keep up with. That's too bad cause I wanted to add an led light bar..
A anyone know how or if it's possible to upgrade the charging system so I can run a light bar?.
And yes the flashing battery light does bother me.. that's a good idea I will check it at the cluster to see the voltage there,. Thanks.
Old 07-11-2019, 12:05 AM   #7
With the tiny battery and a winch pulling up words of 100+ amps the voltage will sag no matter what. Once you stop the voltage should climb back up, possibly slowly with the weak stator in most chines engines. I had a 2013 Polaris sportsman 500 that I used a lot in the winter for plowing, I saw the battery light quite often and it had a larger battery and a 180w charging system. I would just go play around in the snow for a bit to let the battery recover.
Biggest thing that helped me was to use a float charger when it was parked, started off with the battery at 100% not 80-90% if it had been sitting a few days.
Old 07-11-2019, 12:07 AM   #8
Also the company I bought it from was marketing it and selling it with the plow and winch, advertising it and claiming its good to plow a residential driveway. It's obviously not capable if it dies after 10 mins of use..
Old 07-11-2019, 12:10 AM   #9
Thanks duck 9191. Yes I had it on a battery tender every time it was parked so it stayed full charged. It's too bad cause it's a nice atv. It sucks that I can't run a light bar, or finish my driveway in 1 shot lol.
Old 07-11-2019, 12:15 AM   #10
A bigger battery Will help if you can make one fit. A lot of sxs people will use a car battery in the bed while plowing. I would also check the voltage at the cluster and put a load on it, try to see at that voltage it's blinking. It should stop after a minute or two once the voltage regulator has charged the battery back up some.
Old 07-11-2019, 12:21 AM   #11
I put a larger interstate motorcycle gel battery, I had to cut the plastics to make it fit.. it's much better than the Original Chinese battery, but still dies..
the battery light flashes permanently, key on engine off or engine running doesn't matter never ever seen it stop flashing..
Old 07-11-2019, 08:05 AM   #12
Yeah definitely check at the cluster harness to see what you get there. off the float charger and running it should be fine, maybe a bit high because of these cheap regulators. Just riding around you should have no issues obviously, maybe try another reg/rec and see if both the original and replacement are bad. The one that came on my storm would show output for like a minute then stop.
