09-12-2015, 07:31 PM | #1 |
Fuse Size ? Can't read it even with magnifying glass
My fast blow, cylinder shaped, fuse can not be read for the size it is. Anyone know what size it is on the Rhino 250 or ATA-250D? Also looked at the spare in the holder but it too is barely stamped to make it unreadable.
Are these fuses sized too small? Anyone blowing them? |
09-12-2015, 08:22 PM | #2 |
15A (size: 6*30) maybe the answer, it's the standard 1 in modern (old shit is 10A) Chonda.
Use the old trick: Pencil on paper may get the answer
09-13-2015, 05:56 AM | #3 |
I replaced the stock fuse holder in my ATA250D with a blade type and tried a 5 amp fuse... not enough, it occasionally blew. Put a 10 amp in and it hasn't blown. 10A or 15A should be fine.
09-13-2015, 05:04 PM | #4 |
15 is all I've ever seen on the junk I've had.
ata-250d, fuse, rhino 250 |
