Old 03-02-2021, 11:56 AM   #1
DirtCityTX   DirtCityTX is offline
Hawk 250 vs TBR7 front forks
Hello,
Does anyone know if the forks are the same on these two bikes? I have bent fork tubes on my 2015 hawk and taotao parts direct sales the set for both bikes with the hawk set being about 50 dollars more. They look the same but without technical specs I cannot tell if the length is the same. Any help is appreciated.
Old 03-02-2021, 12:31 PM   #2
TxTaoRider   TxTaoRider is offline
They should be the same. I know they are the same as the brozz 250 (older models) and they are pretty cheap from brozz250.com .
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 03-02-2021, 01:14 PM   #3
I figured they would be the same and as far as the brozz, while doing research I always come across the USD forks. Brozz250 from 2014-2018 non blue eagle have standard forks. Thank you for the help TxTaoRider. Brozz250.com was the least expensive fork I have found. I'll update when I receive my forks to confirm incase anyone looks this up years from now.
Old 03-02-2021, 01:42 PM   #4
Good luck. Where is dirt city texas?
Old 03-02-2021, 02:28 PM   #5
Lubbock
Old 05-07-2021, 01:57 PM   #6
Jdubb94   Jdubb94 is offline
Originally Posted by DirtCityTX View Post
Lubbock
Lol Dirt city is spot on
Old 04-03-2024, 05:46 PM   #7
N7sithis   N7sithis is offline
N7sithis's Avatar
Yo I looked this up years later, where's the follow up?
Old 04-03-2024, 07:10 PM   #8
The TBR7, Early Brozz (standard forks) and Hawk forks are all the same.
