05-25-2008, 03:03 PM | #1 |
main jet internal diameters
Hi
I am wanting to up jet and read in a post about reaming the original. I have a good set of very fine drills but does anyone know of a cross reference for main jet size and the diameter of the hole? I'm looking to start aiming for a 105 and maybe move up from there. Anyone any thoughts? Cheers Frog |
05-25-2008, 04:00 PM | #2 |
If you have a dial caliper. You can find a drill that is 1.05. Thats also how You can do it with the tip cleaners.
05-25-2008, 08:42 PM | #3 |
Yes acetylene torch tip files are cheap and come usually with a tip cleaner/ hole diameter chart stamped in the lid... :wink:
Also for interests sake you could google a conversion chart for machinists that cross reference hole size mm/inch fractions/thousands and letter size drill bits.
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
05-25-2008, 08:46 PM | #4 |
Ok , here ...
http://www.engineersedge.com/drill_sizes.htm Handy hole chart. and good place to look around...at least for me :roll:
05-26-2008, 12:44 AM | #5 |
Be careful, not all Main Jet Sizes Correspond with Drill Sizes!!!
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
05-26-2008, 12:46 AM | #6 |
So what would they corespond with if not mm? All may not be measured in mm but all I have seen are.
05-26-2008, 12:53 AM | #7 |
If you look at a #115 jet from a Mikuni verses a Keihin carburetor the sizes are not the same at all... there is a big difference. So no, not all jet sizes correspond with drill sizes.
05-26-2008, 01:06 AM | #8 |
I stand corrected. Mikuni does use a different indexing number. However on these bikes and most others I have built the mm does match up. Here is the screwed up way Mikuni gets thier numbers.
http://www.ozebook.com/compendium/t500_files/mikuni.pdf |
05-26-2008, 09:02 AM | #9 |
Thanks everyone - I'll let you know how I get on!
regards Frog |
05-26-2008, 09:42 AM | #10 |
I am the one who used the torch tip cleaners to ream my main out. I found the cleaner (file) that just fit into the jet and reamed the next size up, then the next size after that. The torch tip cleaners work well, but it's a slow process and a painful one on the fingers. I would try the files before the drill. It's not hard to mess up drilling something so small and your margin of error isn't very big. When I reamed out my main you couldn't even tell I had done anything by looking at the hole, but it made a BIG difference in the way it ran.
05-26-2008, 09:48 AM | #11 | |
