07-12-2023, 09:27 AM | #1 |
Help with how mt05 ecu works
Im trying to fix a friends bike (chinese moped). Issue is the injectors. When you try to start the bike the injector only fires once. The ecu isnt generating the ground pulses to fire the injector (tested with bulb)
As i understand injector has a permanent live and gets a pulsed Ecu is a delphi mt05 ground from pin 5 on the ecu. What feeds into the ecu that it uses to generate the ground pulses. Is it from generator pickups or tps or .... And if you know what pin the input is on would be really helpful. Just want to workout what feed the ecu is not getting Have tried a spare ecu (cant guarantee it works but unlikely both have the same issue) |
07-12-2023, 10:20 AM | #2 |
Weird update. The original issue is it suddenly lost spark and injection neither worked. Guy shorted the sidestand switch and that brought the spark back. I just removed the short and now it runs fine....why would the sidestand circuit be related to whether the ecu fires the injector? Very confused here haha
07-12-2023, 10:48 AM | #3 |
Glad you figured it out.
07-12-2023, 11:40 AM | #4 | |
Nice fix!
07-13-2023, 02:38 PM | #5 |
Having a safety switch on the kickstand is not unusual (well, it is for Chinese bikes but not for brand name bikes in general) and the intent is to prevent the user from riding off with the kick stand deployed, ready to unexpectedly dig into the pavement and send you ass over heels. Typically these are part of the kill switch circuit, and will cut the engine either via grounding out the CDI or preventing fuel injection, or both, if the bike is put into gear with the kickstand down.
