04-11-2023, 10:34 PM | #1 |
Who manufactures magician 250
I bought one but it’s back ordered. Was researching and can’t find the manufacturer to see if it’s approved for road in mass. Having trouble finding the list also. I am also curious what the newest model year is.
04-12-2023, 08:16 AM | #2 |
The easy way to check who made the motorcycle is to check the engine #. It will start with 2 letters and there you will see who made it.
04-12-2023, 08:33 AM | #3 |
The manufacturer is Chongqing Haosen Motorcycle Co., Ltd.. The Magician and Standard Hawk are not EPA approved for street use. They are classified as Dirt Bikes and EPA approved for Off-road use only. Many states will still register and tag them for street use as they will have everything needed to make them street legal.
04-12-2023, 09:44 PM | #4 |
Thanks
Thanks for the info. I ended up switching to the Tao trb7. Not sure when the magician would be in. Seems like it may be a better bike anyways. I would think it should be able to reg. For road in mass. Has everything it needs and the site says it’s dot approved and epa approved.
I’m just learning and am looking forward to having a motorcycle again after 30yrs. |
04-12-2023, 10:26 PM | #5 | |
I have both a standard base model Hawk, and a TBR7, and I have them both road legal here in West Virginia, but I think that technically the TBR7 is probably the easier one to get registered, if you either live in an area were the DMV is stricter, or maybe just have to deal with an employee who is a stickler , because the TBR7 has a metal placard attached to each side of the swing arm, declaring that it is approved, and declared safe for highway use, I forget what the other placard states, but something similar . My Hawk doesn't have either placard, just the VIN stamped into the neck of the frame |
04-12-2023, 10:28 PM | #6 |
Thats great, love mine a 2021 TBR7 4800 miles.
magician 250cc, manufacturers, massachusetts |
