01-27-2022, 03:23 PM | #1 |
TT250 New Bike Bad Battery?
Hi all,
I’m about 2 weeks and 40 miles deep into my new TT250 and very much enjoying it so far. Today I decided to use it for my commute to work and I mapped out a route that was mostly dirt. Bike started fine w/choke this morning. Before I got out the gate, I let the rpms dip too much and it died. Went to re-start and the battery just couldn’t get the job done. I went back up the hill, bump started and then rode to work. This left me wondering if the stock battery is a weak point on these bikes? I’m assuming it might be given the pricing. I’ve been riding every 2-4 days and it was chilly this morning but not that cold so I was a little surprised it only had one start worth of cranking power. Have others had a similar experience? What batteries have people been happy with? Scott
Scott CA High Desert Currently: 2021 TT250 1981 XL 185 project 2003 Buell Blast P3 (for sale) Formerly: 1986 Suzuki GS450 1979 Suzuki GS400 1968 Honda CT90 1974 Suzuki TS250 1978 Honda XL175 1997 Suzuki GS500E |
01-27-2022, 05:17 PM | #2 |
Contact CSC first. They stand behind their products, and you should see what they say before you spend money out of pocket for a battery.
01-27-2022, 05:23 PM | #3 |
Being that it is a new bike, i would first try putting it on a trickle charge overnight. With only 40 miles on it, it may not have received a good charge yet.
01-28-2022, 12:06 AM | #4 |
Good suggestions both. I may have been too quick to assume it came with a junk battery. I’ll hook it up to my trickle charger and see if that makes a difference. Those 40 miles have been across 4 trips in the dirt so if the battery was low to begin with it could still be running a deficit. It started fine for my afternoon trip home, but I only had to crank it over once and the weather was warmer.
If a trickle charge doesn’t fix it, I’ll check with CSC. I want to pick up some spare parts from them anyways. As this is the first new vehicle I’ve ever bought I’m not yet in the mindset yet of “take it to the dealer”.
01-28-2022, 05:01 AM | #5 |
I'd check to see if the charging system is working. Sometimes the regulator/rectifier connectors come loose.
01-28-2022, 06:49 PM | #6 | |
Note: I just began uncrating a TBR7 and the sealed battery that came with it was registering 10.9V so I put it on a charger. It is back up to charged state now, but we will monitor is after installation to verify that it has charge going into it when the bike is running (and that it starts the bike ) |
01-29-2022, 01:57 AM | #7 |
I took a look today and the battery was sitting at 12.5 volts. This is after a 25 minute ride home from work yesterday and sitting for about 24 hrs. With the engine at idle it was around 13v. I put it on my 1.5 amp “Battery Companion” and it switched over from “charging” to “charged” in about 15 mins. Looks like all is well and the other morning was probably a fluke maybe influenced by cold weather.
I see harbor freight sells a battery tender with an attachment setup for installing on the battery. I might pick one of those up for $20. I was always taught to disconnect batteries before charging, but obviously you’re not doing that with a trickle charger w/a permanent connection. Was “needing” to disconnect the battery a myth?
01-29-2022, 07:51 AM | #8 | |
01-29-2022, 12:10 PM | #9 |
China bike batteries, by nature, are junk. You never know how old they are in "new" bikes. None of mine lasted more than a year, an any of my China bikes, (with the exception of Q) before replacing and it was always cold weather that took them out. Keep your eye on it.
02-01-2022, 09:01 AM | #10 |
A motorcycle battery is small and discharges quickly. (Captain Obvious here). Using a battery tender certainly helps.
Air cooled carbureted engines operate a bit different than water cooled fuel injected engines. Listen to how the engine sounds when you crank it. From a dead cold after sitting a bit, you'll need full choke. Keep the RPMs up a bit after starting to warm it up. Knock the choke to half and watch the tachometer to see if it's still bouncing. You'll feel the engine warm up. Kill the choke and let it idle a bit before climbing on. Running the stock 102 jet also affects performance. I installed the 112 jet on my TT and my wife's TT. It makes a HUGE difference in performance, and a noticeable difference in starting procedures.
___________________________________ 2021 CSC TT250 - Silver (Mine) "Buzz" 2021 CSC TT250 - White (Wife's) "Seymour" 2021 CSC TT250 - White (Daughter's) "Gemini" Last edited by Hunnicutt; 02-01-2022 at 10:37 AM. |
02-01-2022, 09:53 AM | #11 |
If it keeps acting up CSC will definitely give you a new battery. My buddy’s TT had a bad battery after about 3 days use. They sent him a new one no questions asked.
