Old 08-12-2020, 07:19 PM   #1
Hirales   Hirales is offline
New carburetor
Can anybody help me figure out how to put this on i just got in today and have no clue what goes where and what pieces I dont need if someone could help 9t would be greatly appreciated
Old 08-12-2020, 07:47 PM   #2
dirtbkr188   dirtbkr188 is online now
dirtbkr188's Avatar
If you took the carb out of the box and it looks exactly like the picture above, you have to remove the intake manifold and flip it around 180°. The carb is upside-down in the pic above.
Old 08-12-2020, 08:27 PM   #3
Ok i have it like this so far but I do not know where all the houses are suspost to go
Old 08-12-2020, 09:32 PM   #4
Bruces   Bruces is offline
Did the original carb not look very much the same ?the hoses go in pretty much the same locations .The one from the tank goes to the vertical nipple beside the pink hose in the picture you posted above ,and the other hose is the bowl drain which goes on the bottom of the carb .
Old 08-12-2020, 10:23 PM   #5
Here's another picture
Old 08-12-2020, 10:31 PM   #6
[QUOTE=Bruces;344392]Did the original carb not look very much the same ?the hoses go in pretty much the same locations .The one from the tank goes to the vertical nipple beside the pink hose in the picture you posted above ,and the other hose is the bowl drain which goes on the bottom of the carb
No they don't look nothing alike there were alot more hoses on the original carb. I put to gas hose next to the pink one that you mentioned and the drain one on the bottom thats just on clamp thats on the engine there kn the picture. But where does that pink hose go thats next to the gas?
Old 08-12-2020, 11:12 PM   #7
It’s just a vent ,it doesn’t go anywhere ,just attach it like the original picture shows
Old 08-13-2020, 02:25 PM   #8
So the pink one is just a vent or should I hook up this hose to it. If not do you know where this hose is supposed to go
Old 08-13-2020, 03:30 PM   #9
That’s an emissions hose ,it should go straight into the garbage unless you need it to be legal where you live .
Old 08-13-2020, 03:44 PM   #10
Ok so just take the hose off all the way
Old 08-13-2020, 03:53 PM   #11
Or can I just zip tie it to the frame
Old 08-13-2020, 04:20 PM   #12
You can do what you wish with it ,I don’t see the point in riding around with extra junk on your bike that isn’t connected anymore ,but if you like it by all means zip tie it to the frame and once a year you can buy it a birthday cake or a dozen roses if you prefer .
Old 08-13-2020, 04:24 PM   #13
Looking at your pictures it appears you haven’t checked your valve clearances yet ,judging by the perfect paint on the valve cover caps ,you might want to figure that out next if you actually want to ride your bike with it running well .
Old 08-13-2020, 05:05 PM   #14
What do you mean by the valve clearance where is that at
Old 08-13-2020, 07:03 PM   #15
On your bike it’s actually in 2 places and probably at zero .You should be able to google valve clearance adjustment for a Honda z50 ,just do what it says and you will be fine .
