06-22-2020, 05:36 PM | #1 |
I need helppppp brand new Lifan xpect 200 no spark and the fuel pump won’t turn on tx
I need helppppp brand new Lifan xpect 200 no spark and the fuel pump won’t turn on tx powersports hasn’t been any help
06-22-2020, 05:45 PM | #2 |
Check for burnt fuse and check all connections.
06-22-2020, 05:50 PM | #3 |
I’ve gone over everything, at first the lights weren’t turn on either when the key was on, I moved the green ground on the relay behind the head light and added a ground to it. The lights came on and the bike started then it died and just turns over now. I have been searching the internet YouTube etc for days. Tx powersports has been absolutely no help
06-23-2020, 07:43 AM | #4 |
This may not be helpful, but thought I would share. My xpect started blowing the main fuse constantly. Figured I had a short somewhere. Finally found it in the large bundled together group of wires between the left fork tube and the head tube of the frame. Had to peel back the tape and wire protective wrap to find it. I relocated that wire bundle after I fixed the wire. No more shorts!
06-23-2020, 08:58 AM | #6 |
Ok guys thanks for the info
