Old 08-07-2017, 09:06 PM   #1
pistolclass's Avatar
Benelli TnT
Looks like china bikes will be more mainstream.
http://www.motorcycle.com/manufactur...view-html.html
Old 08-07-2017, 09:32 PM   #2
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Interesting little bike with impressive looks
Old 08-08-2017, 01:05 AM   #3
Nice!
Nice find pistol
Honda CBR300
Or twin benelli...i like its looks over the crotch rocket style Honda
Old 08-08-2017, 09:48 AM   #4
$4327 out the door
http://af1racingaustin.com/benelli/b...i-tnt300-8ebj6
2017 Benelli TNT 300 (Black)
3,499.00 3,999.00
ON SALE NOW
$500 OFF PRICE OUT THE DOOR IS $4327 including all taxes
Old 08-10-2017, 08:56 PM   #5
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
They're apparently pretty nice bikes. Seen a few YouTube reviews on the 300 already.
Curious at the 0-100km/h time, it seems a bit honest; the Ninja 300 has slightly less power but clocks a quicker time, if I recall. I wonder why a bike of similar weight and power (a couple more horses) is a little slower; geared longer, perhaps.
It has pretty big tyres for its size.
Old 10-08-2019, 01:41 PM   #6
ChopperCharles   ChopperCharles is offline
ChopperCharles's Avatar
I took a test ride and really loved it. The sound it makes is awesome, and it's a full-sized motorcycle with a top speed around 100mph. It easily cruises at 80 and still has plenty of beans for passing.
Charles.
Old 10-08-2019, 02:59 PM   #7
bogieboy's Avatar
i dont get how they get 38 hp out of the little inline twin 300, but we can only get about 15 out of a 200-250cc single.... wheres the massive power loss? is there taht much room for improvement on the small cg and cb???
Old 10-08-2019, 03:09 PM   #8
Liquid cooled, higher compression, OHC,4 valves per cylinder, Red lines @ about 12,000 rpm.
2020 Kawasaki Vulcan S
Old 10-08-2019, 04:54 PM   #9
CG and CB motors will never make that kind of power. 2-valve pushrod motor is a completely different class. Even the Virago V-twin motor only pushes out 19hp out of a 250cc twin. It's a 2-valve-per-cylinder single overhead cam aircooled motor.
Going 4-valve heads is a way to get more power.
Tighter tolerances and higher compression is a way to get more power. But this generally requires water cooling. Spinning the motor faster is a way to get more power. But pushrods can't go that fast, so overhead cams are required. Timing the exhaust and intake valves more precisely is a way to get more power. And that means independent intake and exhaust cams.
All of this adds up to make a far more complex motor than the CG mill. But also a far more powerful motor. And modern machining and metallurgy allows it to still be completely reliable.
Charles.
Old 10-09-2019, 08:08 AM   #10
bogieboy's Avatar
Charles.
pushrods can go that fast with the proper valve springs and cam profile...LOL my little 110cc pocket bike that got me started down the chinese path got some serious upgrades, and could do 67 mph GPS confirmed on flat ground, mikuni vm26, and a high lift cam, would pull hard all the way to 12,000 rpm...air cooled, 2v head... however that was OHC... but still impressive for a 110, considering my 200cc roketa pushrod motor can only achieve 62-65 on flat ground...
that thing was a wicked little bike...LOL not the most reliable though...
Old 10-09-2019, 11:45 PM   #11
Yes, sure, you can build a pushrod motor that can go faster. You build out the other areas to their maximum, and take the hit on RPM. But all things being equal, if you went OHC of some sort you'd be able to spin that same motor faster and make more power.
Pushrods just have too much mass to allow the engine to spin fast. Unless you can make them really, really short, you're looking at 7000-8000 rpm, max. The TNT300 redlines at 13,000 rpm.
Charles.
Old 10-10-2019, 07:58 AM   #12
bogieboy's Avatar
Charles.
nascar runs pushrod motors to 10,000rpm and makes 850hp out of 358 cubic inches...
using that power to displacement number, a cg200 should theoretically be able to make 28hp, and a 250 theoretically could make 35...
wouldnt that be nice..LOL anyone got any ties to nascar engine builders? see what they could come up with for a china bike...LOL
Old 10-10-2019, 11:04 AM   #13
1cylinderwonder   1cylinderwonder is offline
Hehe High horsepower, Limited mileage
You’ll also be lucky if your cg200 and cg250 can run farther than 500 miles, like most of the NASCAR vehicles are lucky to do! with their high horsepower and low reliability!
Old 10-10-2019, 11:25 AM   #14
bogieboy's Avatar
would be a fun 500 mi though my friggin bike hasnt left my yard in 2 years....
Old 10-10-2019, 04:46 PM   #15
Yes, it's possible. NASCAR did this by moving the camshaft as high in the motor as it can go, making the pushrod lengths very short. With less mass to move, the engine can spin faster. Using exotic, expensive, ultra-light materials also helps with this. With deep pockets you can do much. But the only reason NASCAR does this is because the rules say you have to use pushrod engines. If they continued to pour money into motor design without the pushrod restriction, I guarantee they'd all be running dual overhead cams. You can just make more power that way.
Charles
