09-27-2023, 11:36 AM | #1 |
Oil Leak on Hawk 250
About to roll over 5000 units and started smelling burnt oil occasionally at stoplights. Since the bike is not smoking, I looked closely and found this. How serious is this? How can I fix this? Do I even need to bother? I checked the oil level, and it seems to be fine, so the leak is slow.
Any advice would be appreciated. Thanks. Edit: I have come to the conclusion that it's a head gasket leak (please correct me if I am wrong). I contacted PSM, but I doubt it's covered under warranty and just wanted to find out how much a replacement gasket would cost. I am 100% sure I can do the work myself as I have access to a torque wrench and several excellent videos of the procedure on YouTube. But my big question is this: How long can I go before I have to deal with this? Would tightening the head be worthwhile, or should I just do the gasket? Also, any additional advice would be appreciated. Thanks in advance.
2022 Hawk 250 Last edited by Zapkin; 09-27-2023 at 12:31 PM. |
09-27-2023, 12:30 PM | #2 |
gasket bad. gonna have to pull the head. shouldn't be too terribly bad to do. It can wait though, not urgent. a good bit of fresh oil there though, so I'd say "soon".
Dave Bikes I've owned: Suzuki GS450T, Yamaha XS500, Honda V45 Sabre, Kawasaki Vulcan 1500 Classic (2), Suzuki VX800, Kawasaki Ninja 650, Triumph TT600, Honda Superhawk, Kawasaki Concours 1000 (3, including a sidecar rig), Buell XB9R, Kawasaki Nomad 1500, Concours 14, Honda Goldwing (2), Housen Hawk, Suzuki Intruder 1400, Kawasaki KLR650, Victory V92TC. |
09-27-2023, 12:35 PM | #3 |
since this is my daily driver, I will need to repair it sooner than later. But that being said, winter is coming, and I would love to put it off. Thanks for the help.
2022 Hawk 250 Last edited by Zapkin; 09-27-2023 at 04:52 PM. |
09-27-2023, 01:10 PM | #4 |
If it were me I would attempt to tighten the head bolts. If this all of a sudden came on, the gasket could need to be repaired quickly. If like the leak on my Snapper lawn mower that’s still leaking it’s still not much more than a wash job every once in awhile. The leak started 10 years ago. Just my thoughts and the repair isn’t difficult if needed!
09-27-2023, 01:43 PM | #5 |
I agree with J4fun. Maybe check head bolts and snug them up. It might not be a permanent fix, but it will give you time to deal with the gasket replacement during the winter. That would be a good time to d some porting.
09-27-2023, 03:44 PM | #6 |
The oil passes through to the head on the opposite corner of where you found the leak. On the fiber style head gaskets there is also an O ring used to help seal off that corner.
As suggested, try to snug up the head bolts and see if that helps (24ft-lbs). If it keeps leaking, pick up a TT250 headgasket, which is steel and does not require the O-ring. Also a bit thinner so it gives a small bump in compression.
09-27-2023, 04:04 PM | #7 |
The Brozz 250 also uses the metal gasket.
https://shop.brozz250.com/eshopprod_...r_Assembly.htm
09-27-2023, 04:23 PM | #8 |
its in my cart. 12.95 from california scooter company. thanks.
2022 Hawk 250 |
09-27-2023, 04:25 PM | #9 |
whoa..looks like the one from the brozz site is half as much.
2022 Hawk 250 |
09-27-2023, 05:06 PM | #10 |
Maybe it is indeed a head bolt issue, and will seal up. Maybe!
Then you can send back the head gasket for refund.
09-29-2023, 03:01 AM | #12 |
I think if I am going to pull it apart to torque it down (ordered a torque wrench, never had one) might as well just change it. Also the digital dash is coming so i figure take it all apart at the same time. I will also take that time to install the turbo charger that I 3d printed.
2022 Hawk 250 |
09-30-2023, 02:34 PM | #13 |
i cleaned off all of the oil you see in the picture. Then I took the bike up Miller Hill (deep gravel miserably first gear all the way) and at the top I could smell oil. I rode it home. Since then I've been to moundsville a few times and I cant sense a loss of compression. But, very soon I am going to fix it. I cant freakin wait!!! (im not kidding!!)
https://maps.app.goo.gl/KCpNPm9M5ii2ecVk6 i know it is not good to push it, but truth is a whole engine is so cheap and the fact I get to learn in the process..its a win win. Thanks. plus..its a Hawk.
2022 Hawk 250 |
09-30-2023, 03:00 PM | #14 |
I would bet it's leaking around the O Ring, but it sounds like it's not really hurting anything, as long as it doesn't run low on oil.
09-30-2023, 03:12 PM | #15 |
i will tear it apart. I need to tear it apart. I want to tear it apart. and I will fix it. and then I will laugh at myself for ever being stressed out about it. tomorrow I am going back out. hell i might do it today.
2022 Hawk 250 |
