09-03-2018, 11:06 PM | #1 |
Hawk HP?
I'm curious. How much HP does a factory hawk have? Seems every seller I look at lists a different HP rating for the hawk starting at 10.5 and some going up to almost 15. A 50% increase in power is pretty significant.
Anyone dyno their bike after their mods? |
09-04-2018, 04:03 AM | #3 |
09-04-2018, 07:34 AM | #4 |
Lol! OK thanks guys, I never even thought about the possibility of someone mistakenly listing kW as HP rating. I though 10 HP seemed a little low for an engine this size
11-07-2018, 09:23 AM | #6 |
that's quite a jump. what changes did you make?
11-08-2018, 11:58 AM | #9 | |
Are those numbers "at the wheel" with all the other parasitic loses down the line after the engine? I see some places like to "fudge" the high numbers a bit and just have the engine directly bolted to a machine to see how much hp/kw it makes... a 15kw engine can easily drop down to 10kw "at the wheel" when you add those "parasitic loses", things like the transmission, sprockets, gearing, chain, and wheel can eat up a good amount of power
11-08-2018, 12:09 PM | #10 |
15 kw is about the same as the hawk 229, isn't it? that converts to about 15 hp....which is likely at the motor?
11-08-2018, 12:20 PM | #11 | |
The last one was a Qlink, years ago.
11-08-2018, 11:17 PM | #13 | |
11-09-2018, 01:14 AM | #14 |
The official Hawk 250 rating is 14.1hp@7000rpm from RPS completely stock with it's too lean carb jetting and silly restrictive exhaust. I could easily believe 10whp on an unmodded bike. With proper carb jetting, around 15 - 16hp isn't too unrealistic. Take care of the two biggest restrictions - head ports and the exhaust, and 18-19hp on a 26mm venturi carb is right int he ballpark. With a 30mm carb you should be right around 20hp or so, depending on factors. This is all crank hp numbers, but not unrealistic ones.
11-09-2018, 02:55 PM | #15 |
Yeah i can convert it to motor hp. It say it 18.1 hp
