Old 02-18-2018, 06:58 PM   #1
imapdog   imapdog is offline
imapdog's Avatar
another wont run without choke on at least 1/2. 250 hawk
sorry for the 100th person complaing about shutting off when choke turned off. i installed the mikuni carb with 120 jet. i have upgraded the pipe exhaust too. leaning the idle screw doesnt help. warmed up to operational temps and bike runs great top end and bottom. problem is choke is half on and quits when turned off while ridng. i cant even pump the throttle to keep it runing. all i adjusted factory mikuni was th jet. should i have messed with mixture/fuel screw or used 115 jet or lower? here is a pic of my mikuni.
http://www.chinariders.net/album.php?albumid=230
Old 02-18-2018, 08:18 PM   #2
zach3697   zach3697 is offline
Usually for me when something doesn't run without the choke it's because it's not getting enough airflow through the carb to pull the fuel with it. I would just check for any leaks around the intake of the bike. You can try running it with the choke on and then spray some carb cleaner around the seals of the intake and listen for an increase in rpm. If there is then that surface isn't sealing like it should.
Sent from the mobile client - Forum Talker
Old 02-18-2018, 11:45 PM   #3
look into the intake end of the carb and move choke to all positions to make sure where on is and off is. some of the Chinese buggers are upside down to normal thinking.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 02-19-2018, 12:11 AM   #4
Angus67   Angus67 is offline
Angus67's Avatar
Half choke is half wether upside down or right side up. Im struggling with erratic idle with oke off. Runs great half choke. But idle is high. No doubt i need a bigger pilot jet. Sounds like you do too, if you have no intake leaks
2006 roketa 200cc
1971 Yamaha xs650
2x 1980 xs650, 1 is a café, other is a chopper/brat
1972 Honda xl250
2x early 90's Honda rf600 parts bikes
more mc junk laying around.
Old 02-21-2018, 12:15 AM   #5
most will run at half choke but if your putting it to full choke it will die thats why i mentioned make sure which was is on and off by looking into the carb for the butterfly position.
2016 hawk
kaw h1 400 tripple
