Old 07-23-2017, 12:17 AM   #1
Brett   Brett is offline
GY200 problems
I last posted in 2014 after buying both a used Yamoto and Lifan GY200. I've spent the last 3 years, when I've had time, building one good bike. Yesterday, I decided it was time to start the bike for the 1st time and it fired right up. Here's the issues I'm having:
1. The engine didn't seem to have a lot of power. I couldn't spin the back tire in the gravel.
2. The clutch seemed to slip under hard acceleration. I loosened the clutch cable and that didn't help. Using diesel oil in the crankcase, I think 15w40.
3. After I rode up and down the street, the bike died and would restart, but then died again, unless I kept the throttle open. I'm running a new Keihin carb with a new unifilter and fresh gas.
4. The original owner put an iridium spark plug in, could this be part of the issue?
Any thoughts would save me a lot of troubleshooting!
Thanks in advance.
Old 07-23-2017, 05:23 AM   #2
pete   pete is offline
pete's Avatar
I think you need to look at the carb...
you say a new keihin... was it or did you jet it for your motor...
Sounds like it could be lean... revs ok but no power can be a sign of a
lean mixture...
or it's picked up some dirt & blocked a jet...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
