04-21-2017, 06:47 AM | #1 |
Snapped lug bolt, Rhino 250
Snapped the lug bolt (torqued to 35lbs) , need to source a replacement in a hurry.
I took the bolt to H Depot and it's very similar to an flange M10-1.25 by 25mm Unfortunately the bolt won't tread correctly. Please help me source new bolts.
12/2016 Rhino 250 |
04-21-2017, 07:18 AM | #3 |
Hub is good, I've used the other bolts to make sure the threads are good.
I'm going to have to try that smaller bolt idea. Thanks
12/2016 Rhino 250 |
04-21-2017, 08:06 PM | #4 |
I think you need a 1.50 pitch bolt, not the 1.25 pitch.
04-21-2017, 08:52 PM | #5 |
That is correct, bolt m10-1.50 pitch worked perfectly! length is 30mm.
Thank you everyone
12/2016 Rhino 250 |
