Old 04-08-2017, 08:00 PM   #1
jbfla   jbfla is offline
New Beak
It probably wouldn't bother most, but I like parts to fit together properly.
So I ordered a new beak because the plastic hole where the screw goes was stripped.
The screw secures the front edge of the tank panel, and the panel stays in place just fine without the screw.
I don't know exactly when it happened...you know it must be my fault...
New beak:
But when I installed the new beak, the mounting hole was ~ 1/2" from lining up with the body panel.
So I still don't have a screw in the front of the body panel.
I think I have traced the problem back to the fuel tank.
If the fuel tank is mounted just a bit off center, the panel doesn't fit flush against the tank, and the hole doesn't line up.
The other possibility is that the pieces of the body panel (panel is made of multiple pieces) is misaligned.
The next time the tank is removed, I will try to persuade the panel to go into place.
I don't know why this misalignment irked me, because the tank panel bolts that mount from the inside don't line up either...
I've long since left them off, with no ill effects.
jb
2014 XT 250........
Old 04-08-2017, 08:55 PM   #2
fjmartin   fjmartin is offline
Those two screws have been stripped on mine for a long time. I still put in the screws with a lot of locktite and so far the screws haven't fallen out. I've though about things that I could do to resolve like some a brass insert glued or screwed in.
2017 BMW F800GS Adventure
Old 04-09-2017, 07:11 AM   #3
willy dog   willy dog is offline
willy dog's Avatar
mine was stripped put jb weld in the hole and drilled new hole but its a pain to line up so i just leave it out
Peace and Zong Life
Old 04-10-2017, 10:50 AM   #4
Mine stripped also and I just ran a fatter/slightly longer screw in each of them since it was just plastic. Works great now!
My biggest worry when they were stripped was one falling out and me running over it and getting a flat.
Old 04-16-2017, 08:23 PM   #5
3banger   3banger is offline
3banger's Avatar
I always figure those would strip eventually. My plan was to always just drill a through hole and use a nice stainless button head from the top where the a little nut.
Old 04-16-2017, 08:52 PM   #6
Great idea, 3b.
If I can only get the holes to line up...
jb
2014 XT 250........
