Old 12-05-2017, 08:52 AM   #1
Fixemupguy   Fixemupguy is offline
Spark nightmare
Hey all I am new here sent by vmc, I am having issues with spark on a 150 gy6, if I toggle the kill switch rabidly it will spark. I had it running and throttled it up it died and this is where in at, any ideas? Thanks in advance
Old 12-05-2017, 09:15 AM   #2
humanbeing's Avatar
1st: Make sure the wiring is in OK state, ie. no continuity btw Ground (green) & off line (black / white)
DiY something that can measures "peak value"
Old 12-05-2017, 10:39 AM   #3
Spark nightmare
No continuity between green and black/white, it's odd that it'll spark when I toggle the kill switch
Old 12-05-2017, 12:22 PM   #4
tortoise   tortoise is offline
One troubleshooting strategy is removing the key-switch pin from the CDI connector . . to verify the gremlin is in that circuit. If the engine does start, kill it by separating the pick-up/trigger-coil bullet connector.
Old 12-05-2017, 01:25 PM   #5
I will give that a try, I can watch the spark come and go when I toghle the kill the key switch I actually had to play with when this buggy first came to my shop, but has been working since, the circumstances are odd to me
Old 12-06-2017, 07:27 AM   #6
Still no spark unless I toggle switch so I guess it's on to replacing parts, I'll keep everyone posted
