11-06-2016, 04:26 PM | #1 |
No Spark from Hawk
Was out for a ride when the bike just quit when running about 30 mph, trailered it home and sure enough no spark. I have a friend that has the same bike, so i swapped the coil, no change. swapped cdi box, no change. Checked for continuity at kill switch, that was ok. Visual inspection of wiring and connectors shows no issues. Just looking for opinions before I ordered a new stator. Am I missing anything? Bike is a 2015 Hawk 250 with 1,100 miles on it.
11-06-2016, 05:15 PM | #2 | |
11-06-2016, 06:07 PM | #3 |
First thing I'd do is unplug the kill wire from the CDI box, assuming Hawk uses an AC CDI. If it fires with the wire disconnected you'll know the problem is not with the CDI or stator.
11-06-2016, 07:39 PM | #4 |
We just went through this with a Dong Fang and it turned out all it was was a spark plug (he was even getting spark). Member 'Adjuster' mentioned on that thread that spark plugs can look and act like they are still working, but have an internal crack. Fortunately, they are one of the easiest places to start!
