05-20-2016, 11:24 PM | #1 |
So who has a Storm and wants to work on a Tach Cluster?
If you do, Take pics of the plug under the cluster, The attachment bracket, Underside of the fuel tank to see if a sending unit can be installed, (have to remove tank) and follow the neutral wire behind the drive sprocket to see if a position sensor can be installed. Also if you have a wiring diagram send that as well. Send to hawkclusters@gmail.com and title it Storm info or post here. I was going to order a storm just for R&D as i know i could resell it quickly but having to order 100 Hawk clusters at a time killed my bank account......
05-22-2016, 02:44 AM | #2 |
I'll send you a message, this is Skyteam
On the radar: CSC - TT250 Moto Aventure ride 2020. "If everyone is thinking the same thing, no one is thinking." Gen. Patton. -2017 Suzuki SV650 -2015 BASHAN - STORM Current mods: LED headlight & tail light, LED fog light, JT 428-130 chain, 47t rear sprocket, 4-fuse box, oil-cooler, CSC TT205 hand controls, 32" handlebars, aftermarket 295mm rear shock, digital speedo & tach, USB/12 volt accessory; painted flat-black. -2005 Skyteam ST90 (sitting in pieces) -2003 Buell Blast - SOLD |
05-22-2016, 10:02 AM | #3 |
Do the pictures Barlow posted in this thread help?
http://www.chinariders.net/showthrea...ght=storm+tach
2016 CSC TT250 |
05-22-2016, 12:23 PM | #4 |
I am thinking about getting something like this.
05-22-2016, 12:26 PM | #5 |
This might be cool to install, however, on amazon, these chinese gauges were not highly reviewed. Some worked while others had okay luck with them.
05-22-2016, 05:07 PM | #6 |
Where is the key switch located? Would have to work around that.....
05-22-2016, 05:14 PM | #7 | |
05-22-2016, 05:51 PM | #8 |
Since this unit is only like 25.-3" wide it will fit in the dash real easy. So there is enough room.
05-22-2016, 05:52 PM | #9 |
Here is a vid
05-22-2016, 11:15 PM | #11 |
That appears to be the Koso-DB-01R, which can be had for $99 here:
http://www.sip-scootershop.com/EN/Pr...TurBoCal7w_wcB
2016 CSC TT250 |
05-23-2016, 09:02 AM | #12 |
Take a look at these speedos/tachs
https://cqjianmor.en.alibaba.com/pro...ATV_round.html Very interesting stuff.
05-23-2016, 09:37 AM | #13 |
It is interesting. Some of them have a minimum order quantity of 1. I wonder if that is correct?
2016 CSC TT250 |
05-26-2016, 09:17 AM | #14 |
Would that HAWK tach work for a STORM?
05-27-2016, 01:07 PM | #15 |
I have seen these gauges online and they look sorta cool. Maybe something like this would work.
