Qh200 atv
I Have A Qh200 atv It hasn't been started in a while I put a new battery in it and it still won't crank. Also the indicator that shows what gear I'm in isn't changing when I shift gears I need help fast
Welcome!
Please tell us a little history to create a starting point. Did you buy it in this condition? If not, was it running when you stored it?
I Bought It Brand New About 5 years Ago I Haven't Crunk It Up In About 2 Years I Bought A New Battery yesterday tried cranking it up it wout turn over also wen I switch the gears it doesn't change on the gear indicator
So, you hit the starter button and the engine won't even spin?
I Can Hear It trying to start but it doesn't do anything after that it jus keeps spinning
Ok. To be clear, that means it's turning over. The next step is to determine if it has spark.
Remove the spark plug cap, remove the spark plug from the cylinder head, plug the spark plug back into the cap and hold the base of the spark plug against the cylinder head. While holding the plug against the head, hit the starter button. Do you see a strong blue spark at the plug electrode?
