Old 02-17-2015, 09:27 PM   #1
maverickfe   maverickfe is offline
Battery
Hello I have a 2006HI Bird 250st the battery is bad and I need a new one but the one in it does not look like the right one. can someone help?
Old 02-18-2015, 01:54 AM   #2
Just measure the battery box you have and head to Walmart. Their AGM batteries are pretty good.
Old 02-18-2015, 08:15 AM   #3
Thank you for all your help will need it for my other one to its a
KASEA Skyhawk 250 I don't think the motor on the Hi bird is a 250 any way to tell?
Old 02-18-2015, 01:45 PM   #4
Sure. Tell us the numbers that are stamped on the engine, near the shifter.
Old 02-18-2015, 08:41 PM   #5
they are 167mm then on the bottom is 86601040
Old 02-19-2015, 12:48 AM   #6
67 means 67mm bore, and the MM means motorcycle, 250cc. That doesn't actually mean that you have a 250cc bike, because the chart jumps from 200 to 250; manufacturers tend to round up.
The actual displacement will depend upon the stroke, and your engine is likely to be either 223 or 229cc.
Old 02-19-2015, 08:18 AM   #7
Hey thanks trying to find a headlight and a fuel tank and a service manual for this to. I don't know why but he too the rear brake caliber completely off even everything to the brake pedal arm nothing is there lol. So I am going to need some info to get this working right.
