Old 07-28-2014, 03:57 AM   #1
geo99rge   geo99rge is offline
Doh! OIL drain cap Zong zs200
Good day my friends,
After trying to change the oil on my zong, i over tighten the oil drain cap, with the result to crack it. Is missing drops of oil but i want to ask if the yamaha tw 200 is the same screw? to replace it.
Also some interested info about the zong zs200 gy for oils, please i inform you that by mistake i was running the motorcycle with 1 liter of oil for 2 years, after every change of oil. On the side of the right cover is writing 1.3 liters, so do not get stressed when you put some less oil, zong will keep on going!
Old 07-28-2014, 10:38 AM   #2
Hi geo99rge,
I believe the TW200 drain plug is the same.
One litre of oil is ok, but it is best to use the window on the clutch cover for oil level.
Old 07-28-2014, 11:00 AM   #3
I know but i do not have oil level, is broken, and now i have to take oil out to measure! I glued the oil level with some glue for metals!
The drain plug is more important, thanks for the answer
Old 07-28-2014, 03:08 PM   #4
Grin
hello again i found this not original honda innova and yamaha (cub) for 5 usd from local store. yes cubs generally are very popular in greece as in malaysia and rest south pasific countries due to simplicity. where is the same as tw200 drain plug.
for anyone interested this is the code below image
thank you for your help
Old 07-28-2014, 10:28 PM   #5
That drain plug fit properly?
Old 07-31-2014, 01:37 AM   #6
Any of the following oil drain plugs will fit the Zongshen 200GY-2 perfectly.
Yamaha TW200
Yamaha XT200
Yamaha XT225
Yamaha TT-R225
Yamaha TT-R230
You can replace your broken, oil sight glass with the equivalent, Yamaha part #3Y1-15361-00-00. You could also purchase a new, right crankcase cover for your Zong from Taobao.
http://item.taobao.com/item.htm?spm=...56&ns=1#detail
